Go Back   Automotive Forums .com Car Chat > Honda > Integra
Old 04-15-2002, 10:43 PM   #1
tartan
tartan's Avatar
Send a message via AIM to tartan
Question New cams??
I was thinking about installing new cams in my GS-R. I was wondering if a cam designed for a turbo would mess up a N/A engine. I plan to get a turbo installed down the road, but thought I would get new high performance cams now. Would it help to do so? Is there a big difference between turbo cams and N/A cams? Is it hard to install at home? I'm not a professional but can follow instructions very well. Has anyone installed their own cams? Thanks.:shocked:
Kirby Gotz Moves!!! <( " )> (>" )> <( " )> <( "<) <( " )> (>" )> <( " )> <( "<) <( " )> (>" )> <( " )> <( "<)
tartan is offline   Reply With Quote
Old 04-16-2002, 12:08 AM   #2
M-type
well, i dont recommand that you install in yourself, one little mistake and your valves might just slam into your cylinders. there is a big difference between turbo and na cams. But in both cases if you get the right cams, you'll be able to rev higher with out hurting your engine so why not invest in a better cooling system or save your money for steel sleves and new pistons.
Powered by Honda. NA tuned at 11.8:1
M-type is offline   Reply With Quote
