Go Back   Automotive Forums Car Chat > Ford > Windstar
Old 05-15-2005, 09:56 AM
DRW1000 DRW1000 is offline
Power Steering Fluid Capacity
Does anyone know what the capacity of the Power Steering system is?
My owner's manual just says to fill it to the line (Not much help there) which I thought was odd since they provide a volume for all of the other fluids. My hayns does not mention it either.
I wanted the changed my fluid and since I was alone I decided to try it a different way than what I think is the norm.
I sucked out all of the fluid in the resevoir and then refilled and ran the engine a bit while turning the wheels. I did this about 8 times, enough to have 2 litres of "old" fluid. I then filled it back up.
I just wonder approximately how much I changed (Percentage wise)
Old 05-15-2005, 12:33 PM
12Ounce 12Ounce is offline
Re: Power Steering Fluid Capacity
Per the shop manual, the capacity is 1 litre.
Old 05-15-2005, 03:37 PM
That sounds low but I suppose the shop manual knows
Old 05-15-2005, 09:14 PM
wiswind wiswind is offline
I put a magnefine filter in the return line...that goes into the resevoir.
Old 05-17-2005, 07:41 AM
dandi dandi is offline
Maybe it's just me, but I have a hard time seeing where the fluid is in the little cut-out on the reservoir....! Perhaps the plastic has clouded up over time, but I have to estimate where the fill line is by peering inside the reservoir....
Dan D
Old 05-17-2005, 07:46 AM
It is not just you. I cleaned mine and tried shining a bright light and I still have a hard time seeing the level.
Old 05-17-2005, 08:25 PM
My '96 has a dipstick built into the cap.
