Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Register FAQ Social Groups
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 04-29-2005, 05:13 PM
Chrisgys Chrisgys is offline
Apexi Power intake filter
Hi did someone have or tested an Apexi Power intake filter in an 2G Eclipse GSX. If yes I would like to know what you think about this filter. It's an 200 $ filter so I would like to know if it worth the money.
Thanks
Old 04-29-2005, 06:46 PM
Gsx_hooptie Gsx_hooptie is offline
The Apexi is a good filter, but so are others, for less. Apexi, as well as most companies, haven't posted dynocharts for their filters making it difficult to know which is best.
From a theoretical basis K&N is the best filter. The resistance is slim, the size is larger than others, it's oil based, and it's reuseable. To boot, it's half the price. K&N doesn't get enough respect in the tuning world, probably because it isn't JDM. The other proof behind K&N is that the filter has taken several DSMs to low ET quarters. Apexi can't say the same.
Most JDM brands can overcharge because Import Tuner says they're good for Civics A better bet is to buy the best part for the car, whatever the brand. For performance and money, there are better alternatives.
Not everything Apexi is junk. Their exhaust is nice.
I used to own a DSM.
Originally Posted by Anon.
Capitalization is the difference between, "Helping your uncle Jack off a horse," and, "Helping your uncle jack off a horse." The comma is the difference between, "Eats shoots and leaves," and "Eats, shoots, and leaves."
Old 04-30-2005, 01:23 PM
guitarXgeek's Avatar
guitarXgeek guitarXgeek is offline
Send a message via AIM to guitarXgeek
Re: Apexi Power intake filter
Air filters are only going to do so much. If it flows more air, it filters less. If it filters better, it will flow less. You can't really have both so you need to find that happy medium. K&N seems to have found that happy medium, IMHO.
95 GSX
DSMlink, "50 Trim", and track times coming VERY SOON!
Old 04-30-2005, 04:55 PM
I found this
http://www.raceweb.co.za/Articles/ai.../induction.htm
This is a filter test and the apexi power intake filter filters the most of all and has the best airflow. K&N is not bad to but is not as good as the Apexi
Old 04-30-2005, 07:06 PM
Re: I found this
Keep in mind those numbers are for a Supra. Also keep in mind that the K&N filter for DSMs is twice the size of the one they tested
Your HP gains will vary.
Old 05-07-2005, 06:19 AM
Nayr747's Avatar
Nayr747 Nayr747 is offline
What about ebay filters? They are the dry mesh type just like the Apex'i. And you can drop $170 off the price tag. The thing about tests though is that they need to be done more than once to be credible. If there were three seperate independent tests then I would believe it. There really neeeds to be a Consumer Reports for car parts.
'99 GSX, 5-speed, 60k miles: Greddy filter / RRE uicp / 1g bov / Autometer boost gauge / Injen-copy intake / Megan DP (not installed)
Coming soon! Thx to Blackcrow & nova1313! http://dsm-one.org/
Adopt pets in need! http://www.petfinder.com/
