Go Back   Automotive Forums Car Chat > Toyota > Supra > Maintenance
Register FAQ Social Groups
Maintenance Have questions? Find answers. Help out fellow Supra owners.
Old 05-03-2005, 06:16 AM
lodownlv lodownlv is offline
Send a message via AIM to lodownlv Send a message via Yahoo to lodownlv
oil in intake manafold
hello all i have oil in my intake manfold and throtle body in my 7mgte would this be causing a light black/blue smokeing problem i think its from the crank case vent but not to sure if it is can i totaly remove and cap the crank case vent? also can it be the turbo leaking into the intake and Intercooler lines?
Old 05-03-2005, 10:56 AM
projectsupramk3's Avatar
projectsupramk3 projectsupramk3 is offline
Send a message via AIM to projectsupramk3
Re: oil in intake manafold
Do not remove the PCV system, it is one of the best things going for your engine right now. That tiny bit of oil vapor in the manifold will not cause any noticable smoke. If you do have smoking it's not from the PCV but something more serious. If you are really worried about it you could remove the stock IC and drain/clean it out, you might remove alot of crap and actually notice a change in the engine. Your turbo seals could be bad, I'm sure it's about time for a rebuild anyway. Take the accordian hose off and check for shaft play, lots of oil in the intake and accordian hose, that kind of thing.
Old 05-03-2005, 07:30 PM
their is no oil on that side where the accordian hose goes its all in the intercooler pipeing. i only smoke when i boost reall high
