Go Back   Automotive Forums Car Chat > Buick > Regal
Old 04-24-2005, 12:23 PM
ind3ciso ind3ciso is offline
Removing Starter
How do you remove the starter from a 92 bucik regal 3800.
Thanks.
Old 04-24-2005, 10:55 PM
raybuick raybuick is offline
Re: Removing Starter
I just removed mine from a 94 regal. Disconnect battery. Remove the shield around the flywheel-starter THERE are 2 connections that need to be disconnected from the solenoid part after you remove the 2 main bolts that hold starter down. On my car ,I had to remove the left side fan and remove-loosen serpentine belt because the air conditioning compressor had to be unbolted & moved out of the way to slide the starter out.
