Go Back   Automotive Forums .com Car Chat > Dodge > General Discussion
Old 01-17-2004, 12:16 PM   #1
chatterx
Send a message via MSN to chatterx
Timing sprocket removal problem on 89 shelby daytona... any advice??
Hi, I have a 89 dodge daytona shelby 2.2 turbo, I have removed the motor from the car and stripped it all down, now my biggest problem is getting the timing sprocket off the crankshaft, my manual shows to use a harmonic balancer puller, but the one that I have I can get only one bolt in and cant match any others up to the puller or if I do get at least two bolts to match up the center of the puller is off from the hole of the sprocket, do they make a puller that will pull this off, if so where to get one? the sprocket is a 5 bolt pattern (pic below of the part) Also I think I messed the snow guard up that is behind the sprocket, which I believe this holds the front seal as well. any idea on where to get one of these? Any help would be appreciated
chatterx is offline   Reply With Quote
Old 01-18-2004, 06:43 PM   #2
comp
??? find a different puller, not sure on the cover
comp is offline   Reply With Quote
Old 02-22-2004, 01:09 AM   #3
cody7
otc makes a tool just for that, any good part store should have it, i got mine from my mac tools dealer, the tin shield behind it is a timing belt guide (don't wreck that,cuz the t-belt doesn't last long without it)
cody7 is offline   Reply With Quote
Old 04-06-2004, 08:18 PM   #4
DaYtOnAt2
DaYtOnAt2's Avatar
Send a message via AIM to DaYtOnAt2
Yeah OTC for the puller and try www.newdodgeparts.com if ya screwed up the snow guard.
DaYtOnAt2 is offline   Reply With Quote
Old 04-23-2005, 09:35 AM   #5
shadowowner
Re: Timing sprocket removal problem on 89 shelby daytona... any advice??
I know it's been a while since you posted this message, but I'm having exactly the same problem with a '90 Shadow 2.5 engine. Crankshaft sprocket won't come off, 5 bolt pattern, seal retainer blocking jawed pullers and I have destroyed my Harmonic puller bolts. I know the body of the sprocket has an internal shoulder that the shaft rests against but heat and force won't make it budge.
What did you do????????
shadowowner is offline   Reply With Quote
