Old 04-14-2005, 12:43 AM   #1
GMPowered
Angry Adding Keyless Entry - 2001 Blazer
I am trying to add Keyless entry to a 2001 Blazer that has power locks, but was not originally equipped with Keyless entry. I have the correct key fob and have also installed the RCDLR under the driver's side dash. I understand that the BCM must "learn" that I now have Keyless entry, but have no idea how this is done. Any help would be appreciated.
Thanks
GMPowered
GMPowered is offline   Reply With Quote
Old 05-02-2005, 08:20 PM   #2
KindOfBlue
Re: Adding Keyless Entry - 2001 Blazer
Did you ever get this figured out? You might find your answer in this thread:
Automotive Forums - Keyless Entry Questions
Where did you find an aftermarket RCDLR? What does it look like? I've got a 2000 Blazer LS that I'd like to do the same thing to, but want to make sure it doesn't already have one.
KindOfBlue is offline   Reply With Quote
Old 05-03-2005, 09:43 AM   #3
GMPowered
Rcdlr
Not aftermarket, I bought the GM RCDLR, part number 15042969 (any GM dealer.)
It is located under the driver side dash near the parking brake release. It is a small box about 3" x 2". If the box is not there then you should see the wiring connector.
I still haven't figured out exactly what needs to be done to re-program the BCM..............Any ideas??
GMPowered
