The noise is a loud rattle/vibration that comes from the mid to rear of the vehicle. It only happens infrequently under acceleration at slow speeds when the vehicle is fully warmed up. It stops when I let off the gas or give it more gas. Any ideas would be appreciated!
Re: 1999 Blazer rattle/vibration?
Cat convertor
1995 Factory Blazer Service Manual for sale, PM if interested. |
Could also be the baffles in the muffler. Somewhat common to break loose.
Re: Re: 1999 Blazer rattle/vibration?
That is exactly what it sounds like...I have the same problem with my 99...when I turn a corner and step on the gas it rattles/rumbles and is annoying....been that way for along time... I tell new passengers it's my supercharger kicking in.... But I have had my truck up on jack stands looking from top to bottom for something loose...all checks out, but never thought of the INSIDE the muffler.... I suspect I will have to change one day as I have 159K on her..still muffles sound so I will just live with it until it rusts through....6 years and going strong....'cept for the stupid rumble.... |
Keep in mind too that a plugged catalyst can sometimes shift, breaking chunks off of itself and lodging downstream in the muffler, or a pipe bend. Get it looked into ASAP before it becomes a much costlier repair or a hazardous problem. I have seen holes burned through pipes and mufflers caused by a chunk of catalyst broken free and lodging in the pipes somewhere else.
Had it checked out today, however the noise would not show up for the mechanic -just my luck. The catalytic converter was fine, inspected the visibe parts of the drivetrain, test drove it - could find nothing wrong. I did not see the post about the muffler until after I picked the truck - still could be the problem. I'll have that looked at next time.
I would start looking around at heat shields too and make sure that all of your under-body armor and skids plates are snug. 35 foot-pounds should be snug enough for all of your bolts there.
I had a similar problem with a rattle that was driving me nuts...thought sure it wast the cat at first. Had my wife put it in gear & I applied just a little upward pressure on the muffler & it went away.
Next step I suppose is to see if the muffler is just loose, or a heat shield....better than it being the cat, either way! -Mike |
I have a similar problem with my 99 Blazer, it will rumble in idle and you can feel it in the drivers seat and front passengers seat. It has never rumbled when I give it gas or turn at slow speeds. I just get that darn clunking noise when I turn.
Re: Re: Re: 1999 Blazer rattle/vibration?
Re: Re: Re: Re: 1999 Blazer rattle/vibration?
http://www.automotiveforums.com/vbul...d.php?t=344505
