Go Back   Automotive Forums Car Chat > Dodge > Durango
Old 06-13-2005, 02:18 PM
bogies bogies is offline
Motor RPM's high shifting 1st/2nd/3rd
I replaced the fan cluch thinking that was the problem on my 2001 4.7L
but it still roars when going thru 1st,2nd and 3rd. It also lacks power and down-shifts often. The fluid is full and does not smell burnt. It has 44,000 miles. My warrenty 36/50,000. Any ideas !
Old 07-12-2005, 09:03 AM
port3460 port3460 is offline
I have a '02 4.7 and went thru the exact same problem and almost the exact same mileage. Fortunately I have the extended warranty, because I took it to the dealer and they had no clue what it was. First (2) times I took it they could not duplicate the problem. The third time I had to drive it around for a 1/2 hour with the mechanic to get the problem to appear. First they thought it was:
-valve body and governor actuator in the tranny--wrong
-then I changed the output speed sensor on the tranny myself--wrong
-then after I was able to duplicate the problem for the dealer they believed it was the fan clutch--wrong
-then the dealer thought the radiator was clogged--wrong
-then they discovered the radiator fan was not running at the right speed so they changed that--RIGHT!!!!, well kind of.....
Now the problem appears briefly when its cold out of the garage or after I get out of work. So I don't know what to tell you.
Old 07-12-2005, 09:49 AM
tommychau tommychau is offline
Send a message via Yahoo to tommychau
Re: Motor RPM's high shifting 1st/2nd/3rd
How do you change the rotation speed of the radiator fan? Throught they are preset on the clutch?
Old 07-12-2005, 01:46 PM
Thumbs up
When I replaced the cluch fan, which I felt was the problem all along, I was unfortunate to have bought one which was also defective. I went to Auto Zone and got one made in China for half the price ($49 instead of $101)
Now it runs like new.........Problem solved
Old 07-13-2005, 01:45 PM
boogirl26 boogirl26 is offline
Be careful...could be a start to transmission problems.....check the torque converter.....
