Old 03-20-2005, 07:15 PM   #1
fishmonster13
no heat
my 96 v6 rodeo has no heat , i've installed a new thermostat have tried flushing the whole cooling system , the lines to and from the heating coil are hot , water pump is good ,i checked it when i changed the timing belt. any ideas ,do i just not flush it out well enough ?
fishmonster13 is offline   Reply With Quote
Old 03-20-2005, 07:37 PM   #2
amigo-2k
Isuzu Guy
the rad is probably plugged.
try searching here, that has been a couple of recent posts.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
amigo-2k is offline   Reply With Quote
Old 03-20-2005, 08:15 PM   #3
fishmonster13
Re: no heat
i flushed the radiator seems like it flows thru good
Old 03-20-2005, 08:16 PM   #4
fishmonster13
Re: no heat
i flushed the radiator seems like it flows thru good the temp gauge reads pretty low
Old 03-22-2005, 09:33 PM   #5
fishmonster13
Re: no heat
i figured it out , the blend door is stuck in the closed position due a broken pin from the heater control
