Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Silverado
Old 03-25-2010, 08:32 PM   #1
bigrockk
07 2500hd classic
bigrockk's Avatar
Question Remove moisture from lights
2007 GMC Ext Cab, 2500HD, 6L Gas, with 195,000 KM
Well to have my safety check complete I need to remove the moisture from my lights, can any one tell me how to remove these?
Do I need to remove the grill and if so how to I get it out? I had a look but it doesn’t seem obvious. How would you change a bulb in these, can’t seem to reach them from under the hood very easily. Probably goofy questions I know but appreciate the help once again!
Pictures of the lights are at the link below
http://pbckt.com/sU.v2l
bigrockk is offline   Reply With Quote
Old 03-25-2010, 11:04 PM   #2
mcconnell45
Re: Remove moisture from lights
I'm going off of my '03 silverado for reference but I would imagine your Sierra isn't too far off.
When you look at the headlight with the hood open there should be a metal rod sticking up on each side of the headlight assembly. Unscrew these rods until you are able to pull them completly out. Once you do that you should be able to take the headlight through the front of the grill making it easier for you to either unscrew the bulbs or just unplug the harness.
Now this part I'm not sure about because the design of the silverado vs the sierra is a little different. But on mine once you remove the headlight there will be enough room for you to remove the drl/blinker assembly below it. On my truck there is a white clip you release and just like that the entire thing comes out and you should be good to go.
As far as getting the moisture out someone else may have to touch on this subject. These lights are completely sealed other than were the bulb goes in so I'm not real sure how easy it would be to open the light itself up..or if you even want too do that. Sounds like a heck of a process to get a truck saftey checked up there..good luck!
2008 Silverado LTZ Z71 Extended Cab
"The Winner isn't the one with the fastest car, it's one who refuses to lose." #3
mcconnell45 is offline   Reply With Quote
Old 03-25-2010, 11:59 PM   #3
bigrockk
07 2500hd classic
bigrockk's Avatar
I will check tomorrow after work to see if it is the same. Even if it is somewhat different you have given me some great ideas for what to look for. I’m sure it will be somewhat similar.
Thanks again for a quick reply, this would certainly take a lot more effort without all the help!
I think it is mostly a money grab to be honest, I’m all for safety but some times it gets a little carried away.
Old 03-27-2010, 08:53 AM   #4
j cAT
on my 2000 siL the head lamp is held by 90deg rods no threads ...held by plastic retainer built into the support bracket ...remove these rods spray with a lube first ...with the lamp out the socket key depressed you rotate a 1/4 turn and the socket comes out ..this should take about 2 min...
with the lamp assy removed place the fixture on a warm surface with the socket hole up....the mositure will soon evaporate...
check the edges for proper sealing ,,,add a clear sealer to the edge seams ...on the socket rubber gasket place some silicone dielectric grease ..you will never have this again ...do not touch these glass lamps with you skin as oils/dirt will damage the lamp..
Old 03-27-2010, 10:39 AM   #5
gremlin96
i have a question. my 2004 has been on bad roads. behind coal trucks. even doing some light off roading. i have never had water in the lights. i even hit a spot on the road when it rains the water stands 2ft deep for 100 yards.
how in the heck did you get water in the lights.
gremlin96 is offline   Reply With Quote
Old 03-28-2010, 10:16 AM   #6
bigrockk
07 2500hd classic
bigrockk's Avatar
Smile Re: Remove moisture from lights
Mine are exactly as jcat described. It turns out they are quite easy to remove.
Again Jcat nailed it, the seals on the edges of the lamps are bad, If you look close on the edge there is a white gasket between the lens and the body of the lamp and on mine I could see the gasket was not in properly.
I placed them on the floor register overnight and they look good!
Thanks again for the replies, the help sure makes this easier!
Old 03-28-2010, 10:30 AM   #7
j cAT
you must be careful with the soap used on the washing of your vehicle...acid vehicle soaps must be avoided...these do a great job of cleaning the finish with little effort BUT cause damage.....
only use high quality vehicle cleaning products with no acid cleaners....
soap used at the car wash is not good !
Old 03-28-2010, 10:48 AM   #8
serge_saati
serge_saati's Avatar
Send a message via MSN to serge_saati Send a message via Yahoo to serge_saati Send a message via Skype™ to serge_saati
I'd a tip for you, so you don't need to remove the assembly. Simply, remove the bulbs socket while the lamp are turned on. Not completely, just enough to let the moisture get out. Because the light are turned on, it'll heat, so it'll evaporate.
Maybe the light cover needs also to be cleaned/polished.
Use vegetable oil or even better, acetone (paint solvent) to clean from outside.
2003 Chevrolet Impala LS 3.8L OHV
2002 Ford Taurus SE 3.0L OHV (sold)
1998 Ford Windstar LX 3.8L OHV (sold)
2002 Chevrolet Malibu LS 3.1L OHV (sold)
2004 Hyundai Accent GS 1.6L DOHC manual (sold)
1995 Oldsmobile Cutlass Supreme S 3.1L OHV (sold)
2002 Ford Crown Victoria Police Interceptor 4.6L SOHC (sold)
A Windstar without having the check engine light is not a real Windstar.
serge_saati is offline   Reply With Quote
Old 03-28-2010, 02:14 PM   #9
j cAT
the lamps to remove require little effort , no screws ...to run lamps not properly secured will cause the bulb filament to break with the vibration ...if the housing is wet inside the fixture must be removed to seal the edges anyway..
the use of acetone solvent should only be used on bare metal...this is a powerful solvent and will damage your painted/plastic/rubber and other surfaces.....
use of acetone on the lamp will damage the seal...not good IDEA ...
