Old 03-07-2005, 09:41 PM   #1
yukonbrewster
Question 1988 chev 1500 p/u
I have a 1988 4.3l chev that will not fire , I've replaced the timing chain, gears , cap and rotor . Have spark and fuel but the engine will not fire just turns over . Any suggestions would be a great help .Also spark is weak out of spark plug , hot fr. coil though .
yukonbrewster is offline   Reply With Quote
Old 03-17-2005, 12:06 AM   #2
prong2002
Send a message via ICQ to prong2002 Send a message via AIM to prong2002 Send a message via MSN to prong2002 Send a message via Yahoo to prong2002
1988 chev 1500
If you changed the timing chain you may be 180 degrees off on the timing. To check hit TDC (top dead center). To do so point the crevice on the damper pulley to the 0 degree mark and see if the rotor is pointed to the #1 cylinder spark wire. If it is pointing to the #6 you have to lift the distributor about 3 inches and turn the roter like a door knob in the opposite direction (or 180 degrees).
Just one thing to check.
prong2002 is offline   Reply With Quote
Old 03-21-2005, 08:55 PM   #3
yukonbrewster
Re: 1988 chev 1500
[quote=prong2002]If you changed the timing chain you may be 180 degrees off on the timing. To check hit TDC (top dead center). To do so point the crevice on the damper pulley to the 0 degree mark and see if the rotor is pointed to the #1 cylinder spark wire. If it is pointing to the #6 you have to lift the distributor about 3 inches and turn the roter like a door knob in the opposite direction (or 180 degrees).
Just one thing to check.[/QUOTE
Thanks , checked that and the rotor was not pointing to #1 . Fixed it and still no luck .Motor sounds better though turning over , but still not firing .On to the next problem .
