Go Back   Automotive Forums .com Car Chat > Pontiac > Grand AM
Old 02-10-2005, 09:21 PM   #1
alleyd
99 Grand Am Rough Idle in Drive
I have a 99 Grand Am 4 cyl DOHC, automatic transmission and I have been having a problem with rough idle/vibration while at idle in drive. The second I shift into neutral, park, or reverse the vibration stops. While driving everything seems normal.
I have had the MAP sensor check out, No EGR on the car, a tuneup and transmission service done.
Any ideas on the problem would be helpful!
Thanks ahead of time!
Mary
Phoenix AZ
alleyd is offline   Reply With Quote
Old 02-12-2005, 07:56 PM   #2
FormulaLT1
Fight the powwa!!!
FormulaLT1's Avatar
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: 99 Grand Am Rough Idle in Drive
Welcome to the forum. Have you checked for codes or do you have your check engine light on?
John
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
FormulaLT1 is offline   Reply With Quote
Old 02-13-2005, 02:06 AM   #3
alleyd
Re: Re: 99 Grand Am Rough Idle in Drive
We checked for codes but none are showing up on the scanner and the check engine light is off.
Mary
Phoenix AZ
Old 02-13-2005, 04:40 AM   #4
FormulaLT1
Fight the powwa!!!
FormulaLT1's Avatar
Well sounds like 1 our 3 things to me. 2 have to do with the same thing. I think it could be carb deposits on your throttlebody or IAC casing too much air to enter and a idle surge/causing roughl idle. Your throttlebody attachment screw is misadjusted if you have one or you have a vacuum leak. Could be a great many things but that what I would look into first. Good luck.
John
