Old 02-16-2005, 12:26 AM   #1
Suffakate
Send a message via AIM to Suffakate
Car Idles high, low, high, low, high low.........
Yeah at first the car only did that in park and neutral, now i notice that it will do it when im at a stop light. i can make it go away if i put the car in park and rev it, than put it back into drive...... the car is a 91 accord
Suffakate is offline   Reply With Quote
Old 02-16-2005, 08:54 AM   #2
Ehscrewdude
Send a message via AIM to Ehscrewdude
Re: Car Idles high, low, high, low, high low.........
what is the range of the rpms we are talkin about? (ie: 1000-5000?)
Ehscrewdude is offline   Reply With Quote
Old 02-16-2005, 11:15 AM   #3
Igovert500
blue + red light magnet
Igovert500's Avatar
Irratic idle is usually caused by bad spark plugs, bad 02 sensor, or vacuum leaks.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Cusco front + rear strut bars
-Greddy type-s
-ATR downpipe
-no cats
-15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly.
Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical.
Igovert500 is offline   Reply With Quote
Old 02-17-2005, 11:30 AM   #4
94hondaacc
There Is A Screw Inside Your Throttle Body That Comes Loose. You Have To Remove The Throttle Body Open The Little Cover On It, And You Will Have A Screw That Is Holding Down A Spring. The Spring Has Probably Come Loose And Will Need To Be Put Back In Place By The Screw. Good Luck.
94hondaacc is offline   Reply With Quote
