Go Back   Automotive Forums .com Car Chat > Ford > Mustang > Performance
Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here.
Old 12-08-2004, 11:43 PM   #1
Jep164
Superchager, wear and tear?
hello,
I have a 2000 3.8L daily driven mustang coupe (mods: K&N fipk, magnaflow dual exhuast). I'm getting tired of imports and want to obliterate them all with my stang. In order for this to happend I need a superchager. But, I'm afraid of the wear and tear. Can someone please explain it all to me?
Jep164 is offline   Reply With Quote
Old 12-11-2004, 07:50 PM   #2
bigbob
Re: Superchager, wear and tear?
there was a guy on a nother forum i read this morning saying he has daily driven his 5.0 now for 6 years with a vortech s trim. nevert taken it apart. newer broke, and he says it still makes jstu as much boost/power as it did.
95 gt vert
built aode
underdrive pullies
slp cat back
bbk o/road h
nos dry 80 shot
bigbob is offline   Reply With Quote
Old 12-17-2004, 11:54 PM   #3
burntrice087
Banned
Iam considering a procharger set-up for my 97 Stang V6 and iam not aware of any wear-tear problems....just make sure you buy an intercooled kit and run a safe amount of boost....
burntrice087 is offline   Reply With Quote
Old 12-18-2004, 05:56 PM   #4
ls1mazda93rx7
ls1mazda93rx7's Avatar
i would'nt go with a super charger, it would be better if you threw 4.6 or 5.0 in to. besides superchargers are run off a belt, so it robs horsepower to make horsepower,they cost about 2k-2.5k- fuck you could buy a well prepped v8 crate motor around that price!
ls1mazda93rx7 is offline   Reply With Quote
Old 12-18-2004, 06:05 PM   #5
ls1mazda93rx7
sorry a v6 just dosen't have any power, the car weight is too much for just 180whp. AS far as import tuners i beat a 2003 v6 mustang with my 99 accordcoupe, and the cobras are too much$$$, but i can take'em in a= http://www.bama.ua.edu/~hinso007/Pro...acingSmall.wmv there is no hope for your v6, just trade it in on a gt.
Old 12-26-2004, 05:36 AM   #6
SkylineUSA
SkylineUSA's Avatar
Send a message via AIM to SkylineUSA
My S-Trim has been on my Mustang for over 8 years. I had the rubber intake pipe slip and hit the blade few months ago, so the blades went through the engine. When I took the supercharger apart, everything was tight, and looked brand new except for the impeller of course.
The only real problem is the added stress on the front main bearing, but if you install a tooth pulley, you will not have to crank on the bearing so much, but then again they are kind of pricey. Go with an 8 rib, a 6 will slip.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
SkylineUSA is offline   Reply With Quote
Old 01-09-2005, 12:48 AM   #7
eillob
eillob's Avatar
Originally Posted by ls1mazda93rx7
Damn!
Thats a bad little bastard. The coolest thing about that car besides obviously the motor is that it isn't all riced out. Good work man.
Ported Cobra Intake, Ported & polished Windsor Jr heads, K&N, Vortech s-trim, 90mm Lightining mass air meter, 70mm throttlebody,1.7 roller rockers, BBK Long tube headers, offroad H-pipe, Crane cam, main cap girdle, 40 series flowmaster, 3.73 gears, MSD ignition, CGS subframes, A9L PIH kit, SCT custom burned chip, 42lb injectors, 190lph fuel pump, T rex and fuel pressure regulator, AFCO racing radiator
(If it doesn't scare the Hell out of you it isn't fast enough)
eillob is offline   Reply With Quote
Old 01-09-2005, 01:10 AM   #8
TheStang00
TheStang00's Avatar
idk if that accord was stock or not but if u beat one the v6 stangs it was most likely an auto, those are slow if u got a v6 it has to be a stick, and its 193 hp but its got 220 torque
TheStang00 is offline   Reply With Quote
Old 01-09-2005, 01:12 AM   #9
TheStang00
TheStang00's Avatar
yeah also the main topic... ive looked at some superchargers for a v6, they can get up there pretty high in hp so if u wanna do that its prolly not a bad idea, but if u switched to a v8 motor youd have a lot more potential for power increase, cause then u could still supercharge or turbo that motor later
Old 01-09-2005, 10:54 AM   #10
eillob
eillob's Avatar
Aren't V6's notorious for blown head gaskets. Im forever finding posts where guys are having overheating problems because there V6 keeps blowing head gaskets. Seems to me adding a supercharger to somthing like this is just begging for it. I agree with the others I think trading off that V6 and jumping up to a V8 is not only gonna save you some trouble down the road but make you more power right off the bat. Hell a V8 with the right bolt ons is damn impressive without even talking about a supercharger.
Old 01-09-2005, 11:39 AM   #11
ModMech
ModMech's Avatar
Jep,
Superchargers only affect "wear and tear" when you use the power. Under most (normal) operating conditions, your engine will operate as if no supercharger is installed. When you push on the go pedal, you will activate the S/C, and get the extra power you need (want).
The 3.8L engines were not known for being really reliable, that all changed in about '98 when FMC altered the headgasket design. I have heard of zero problems since then.
Check www.v6power.net for additional info, I think some of their members are pushing 250 RWHP with blown 3.8Ls and they are holding up well.
ModMech is offline   Reply With Quote
Old 01-09-2005, 11:47 AM   #12
TheStang00
TheStang00's Avatar
yeah the newer v6 engines are a lot better then the mid 90's ones, in terms of reliability and power
Old 01-09-2005, 10:10 PM   #13
fbodymustangdude
fbodymustangdude's Avatar
Send a message via AIM to fbodymustangdude Send a message via Yahoo to fbodymustangdude
Dude, you could always build your own turbo kit for the v6, but you gotta make sure you get a good intercooler. Turbos are cheaper and can be suited to any application. Just a thought
91' Caprice Classic
145k, 305 v8 700r4
custom dual exhaust ran through american thunders dumped
92 Mustang
built 302, air gap intake, 650 edlebrock carb,
1.7 rr, full msd ignition, full race fuel system,
built C6 with b&m shifter and 3000 stall
bbk shorties-mac o/r h pipe through cherrybombs dumped
striped interior
--FOR SALE--
fbodymustangdude is offline   Reply With Quote
