Old 01-10-2005, 12:29 AM   #1
Ansel Marrow
Ansel Marrow's Avatar
Send a message via AIM to Ansel Marrow
why wet sand?
im sanding down my body that is painted to get it ready for the second coat. would wet sanding do anything? what does it do as opposed to dry sanding?
Ansel Marrow is offline   Reply With Quote
Old 01-10-2005, 01:10 AM   #2
white97ex
white97ex's Avatar
Send a message via AIM to white97ex Send a message via Yahoo to white97ex
Re: why wet sand?
wet sanding keeps hte paper from clogging and keeps a more consistent grit on the paper.
My name is Russell, feel free to use it.
I'd rather be hated for Who I Am than be loved for Who I Am Not
white97ex is offline   Reply With Quote
Old 01-10-2005, 01:24 AM   #3
fwdfreak
fwdfreak's Avatar
Send a message via MSN to fwdfreak
Re: why wet sand?
In another word, wetsanding avoids f***ups more.
fwdfreak is offline   Reply With Quote
Old 01-10-2005, 01:25 AM   #4
Ansel Marrow
Re: why wet sand?
just wet sanded the body, seems to be a smoother finish than dry sanding. thanks for the advice!
Old 01-10-2005, 06:23 AM   #5
primera man
"P-Man"
primera man's Avatar
Re: why wet sand?
Dry sanding only causes plenty of dust which is very hard to get off the model before painting.
Wet sand the model and when you have finished give it a good wash/brush under hot water and leave to dry
View All My Models Here.
primera man is offline   Reply With Quote
Old 01-10-2005, 08:58 AM   #6
Vric
Vric's Avatar
Re: why wet sand?
also Dry sending is warmer and cause some stange thing on the paint, plastic and resin. Water keep it cold.
Vric is offline   Reply With Quote
Old 01-10-2005, 05:57 PM   #7
bvia
bvia's Avatar
Wetsand with room temp water (70-80 degrees F)and put a drop of dishwashing liquid in the water to help lubricate the surface and break the water's surface tension.
I use a rectangluar Tupperware (plastic) container as oppsed to sanding over the sink.
hth,
Bill
Bill
"Why yes, that IS my bare, carbon fiber Enzo in Scale Motorsport's "How to Carbon Fiber Decaling video!"
bvia is offline   Reply With Quote
Old 01-10-2005, 06:02 PM   #8
mickbench
mickbench's Avatar
Re: why wet sand?
hth,
Bill
I too use a plastic contanier. I wet sanded some primer with 1500 grit and it was really smooth. Problem was I went through the primer. I had to recoat the affected areas.
Still live and learn. I will be more careful with wet sanding. It's fine with no paint, but if smoothing primer etc it's a lot tricker..!!
mickbench is offline   Reply With Quote
Old 01-10-2005, 06:49 PM   #9
Tommycool666
Re: why wet sand?
I don't know about you but i use just water, when i used the dishwashing liquid it left a residue on the body and the paint bubbled and peeled. and i washed the body like 10 times in a row to make sure that wouldnt happen.
Tommycool666 is offline   Reply With Quote
Old 01-10-2005, 07:10 PM   #10
ImolaEK
ImolaEK's Avatar
Re: Re: why wet sand?
Wet sanding is what saves me! Thats the process that i take most of my time doing. Hopefully Airbrushing the paint will lessen the wet sanding. Just be careful wetsanding, just telling you since last time i was watching TV while wetsanding and turned my head for 3 seconds to see the TV and then look back and i ran through the paint
-Joeham-
無限 MUGEN POWER
Email:
[email protected]
MYSPACE
www.myspace.com/joeham
ImolaEK is offline   Reply With Quote
Old 01-10-2005, 08:01 PM   #11
Feint Motion
Feint Motion's Avatar
Re: Re: Re: why wet sand?
Happened to me to many times.. Im heavy handed too.
~Josh~
OldUser:IImportSupra
Do You Have a Car that Goez Sideways?
Feint Motion is offline   Reply With Quote
Old 01-10-2005, 11:40 PM   #12
Ansel Marrow
Re: why wet sand?
i did an excellent wet sanding jon in my opinion, only to ruin it with the final coat of that testors crap. i got the large areas fine, but i got a few bubbles here and there, and some broad orange peel on one side of the car. next paintjob i am definitly using an airbrush.
