Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Silverado
Old 01-08-2005, 12:26 PM
Bodine Bodine is offline
Question Head Gasket Leak
OK bought my 2001 silverado used with 20k miles. Now 1 year later and 50k miles(warrenty ran out at 39k) my low coolant light came on. I then refilled it back up and checked my engine oil and trans to make sure antifreeze wasnt going in there and it wasnt. A few days went by and the low coolant light came on again. Upon inspection i found a head gasket leak on the front passengerside head. I know this isnt normal. Is there a recall or TSB for this? If not what would yall suggest besides me dishin out the $$ to get it fixed. Any help would be great. thx.
p.s. its a 5.3liter
Old 01-08-2005, 01:46 PM
Silverado Brethern's Avatar
Silverado Brethern Silverado Brethern is offline
Re: Head Gasket Leak
Yes fix it asap. coolant inside you engine will be much much more expensive than fixin a bad gasket. As far as recall, i dont know of one.
"Never under estimate the power of stupid people in large groups."
1997 K-1500 Silverado Vortec 350...125,610 and wounded
HD chassis package
Custom TRUE DUAL exhaust with cut-outs and Flowmaster 40 series mufflers
Poweraid Throttle Body Spacer
Custom Ram-air Intake with K&N FIPK GEN II
TFES Performance 3" Suspension Lift
Dual Air-Horn Kit with Compressor
Bed-Mounted 48" Hi-Lift Jack
Cobra Laser Radar Detector
285/75/R16 Cooper Discoverer STT's
1/4 Mile 10/15/05: 16.43 @ 91mph
Old 01-10-2005, 08:17 AM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
There is no warranty for this, as I just encountered the same problem last year. My truck had 75K on it when the head gasket cracked, leaking several tanks of coolant into the crankcase. I never found this until I had changed the oil. After getting the gaskets changed, everything was fine until 20K later. 4 bearings spun one day and the engine completely locked up in the middle of an intersection, I believe as a result from so much water entering the engine. I had to buy a complete engine this time. So be careful...
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
