Go Back   Automotive Forums Car Chat > Car Audio
Register FAQ Social Groups
Car Audio Do you live in your car? Then you need to be able to listen to some high-quality music.
Old 04-15-2004, 10:33 PM
danielnewell2007 danielnewell2007 is offline
Question Removing Factory Radio Of 97Chevrolet 1500
I really need to know the best way to get the dash off, and then the factory radio also
97 Chevrolet C1500 Regualr cab, 5spd 4.3 Vortec
Old 04-21-2004, 04:51 PM
jdrumstik's Avatar
jdrumstik jdrumstik is offline
Re: Removing Factory Radio Of 97Chevrolet 1500
sorry no ones offered help, just look for screws, I know on my chevy van the cup holder thing on the front pops off and reveals screws, you just got to start pullin and see if it gives, they hide the screws all over, they might even be in you manual, just look.
Old 01-03-2005, 01:00 AM
Cadillakin'98's Avatar
Cadillakin'98 Cadillakin'98 is offline
all GM trucks have the easiest dash panels to remove. I have same exact make/model (but '98) and as much as I hate to admit it, we have the easiest-to-break in/steal trucks made. This goes for the radio as well. There are no screws holding it in place so firmly grab by the air vents and pull back, follow the dash trim piece around until all clips are popped loose. From countless times of taking mine off/putting it on I will tell you it is easiest to put the shifter in N to give you the clearance you need to completely remove it after disconnecting the wiring harnesses from whatever switches you have. When that is out of the way, you should be able to seejust how easy it is to yank the radio out, just press the 2 little levers on each side of the radio down then pull it out. I got a little trick I'll share w/you that will make a would-be thief change thier mind on grabbing your replacement radio but you have to ask me first. Not gonna share with everyone out there 'cause then they could become would-be thieves with more knowledge!!
94 civic procedure for removing factory radio ncnative Interior | Audio | Security 3 01-19-2005 06:57 PM
Removing Factory Radio Tomeboy63 How-To's and Walk-Through's 2 12-28-2004 05:03 PM
Dash Lights Out After Removed Factory Radio.............does Anyone Know How To Fix? OLD_SKOOL_MAX Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 2 10-03-2004 05:28 PM
How to remove factory radio and install amp in 97' runner blazzingbrandon 4Runner/GX470 2 07-16-2004 10:46 AM
