Go Back   Automotive Forums .com Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 12-28-2004, 03:27 AM   #1
carmyfreek9101
Angry engine swap
i have a 91 toyota camry, but i am unstisfied with the engine. I have been serching around to see what engine i could put into the car. Does anyone know of any good engines i could instal that i could make a good fast car out of it.
carmyfreek9101 is offline   Reply With Quote
Old 12-28-2004, 01:00 PM   #2
Strider327
Send a message via AIM to Strider327
Swap in a 5sfe if you want to run NA, or a 3sgte motor from a mr2 turbo.
Strider327 is offline   Reply With Quote
Old 12-29-2004, 11:39 AM   #3
JekylandHyde
AF - Advisor
JekylandHyde's Avatar
Re: engine swap
Originally Posted by Strider327
Swor a 3sgte motor from a mr2 turbo.
You may want to consider the Celica's 3SGTE since it's piping and lines are already oriented for the front of a car
Sponsorship: Amateur Motorsports <-- Get the book! - books are now available for shipment
JekylandHyde is offline   Reply With Quote
Old 12-29-2004, 01:20 PM   #4
Toyrolla
Toyrolla's Avatar
Send a message via AIM to Toyrolla Send a message via Yahoo to Toyrolla
If you are going to swap in the 3S-GTE, you will have to also swap the tranny to a manual (if you currently have an automatic). An automatic tranny is not able to handle the power of a 3S-GTE. If you currently have the 3SFE in your car and you go with the 3S-GTE, you will need the engine with the ECU and wiring harness. You will also need to upgrade your front axles to the V6 axles because they are stronger than the I4 versions.
Regards,
Nobody can break it better than me.
88 I4 Slushie, 89 I4 5Sp, 89 V6 5Sp, 82 Corolla, 72 510, 88 Minitruck.
Toyrolla is offline   Reply With Quote
