Oxygen Sensors
If I remove the catalytic converter's on my 2001 rodeo will that cause any problems with my ecu since it has O2 sensors after the cat?
Thanks for any help |
Isuzu Guy
![]() Join Date: Jan 2004
Re: Oxygen Sensors
yes.
-Ryan Isuzu Moderator Car Show Tips Operations manager with a results-driven passion for process improvement FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd |
Re: Oxygen Sensors
It is also illegal. You won't be able to pass an e-check either.
98 Rodeo S/LS 3.2L V6 Auto 4WD 150k |
It doesnt matter i live in the bahamas. we have no emmissions control here.
Isuzu Guy
Re: Oxygen Sensors
It won't even run right. and you will kill your motor super fast
What is your plan more power?
Too bad you don't have a 2002. I'd gladly buy'em both from you (O2 sensors)
!G/luck Joel
2016 Subaru Forester 2.5i base CVT 2016 Nissan Quest SV |
#7 | |
![]() Join Date: Dec 2003
Re: Oxygen Sensors
You might be able to use O2 sensor simulators. I know alot of people get rid of the cats and use them but I havent seen that on a rodeo yet.
#8 | |
Re: Oxygen Sensors
wow i never even knew those existed. Thanks for the great info. Now i have to find out if they will work on my rodeo. Seems they are all for GM and ford. Maby since the rodeo has a few gm parts it might work.
#9 | |
![]() Join Date: Oct 2004
You might consider making your own O2 simulator.
You could conduct an experiment by connecting an amp meter in series with the wires to the O2 probe and then take it for a test drive. While driving observe what the meter is reading during various driving conditions and record these values. Next, with the key switch in the on position, measure the voltage across the wires of the probe. Take the measured voltage and divide it by the high and low current measurements. This will give your the resistance range of the O2 probe. From this value, select a resistive value in the middle for a starting point. Buy a 1 to 3 watt resistor approximately close to this mid point value and disconnect the O2 probe and install the resistor in its place. Take a test drive and see how she runs. You may won't to vary the resistance value for best performance. My
If you want something done right do it yourself two or three times! 1999 Isuzu Rodeo LS 4X4 American Eagle Series 149, 16X8 Toyo Open Country LT265/75R16 Rancho 9000 3" CP Lift, 3" PA Body Lift Manual Locking Hubs, SuperWinch Optima Yellow Top Battery Custom Sound System Shrockworks Rocksliders Letsrodeo |
#10 | |
It's a good plan LetsRodeo, but you do need to vary the resistance readings per this vehicles' programming map, or you will have a perpetual bank 1 sensor 2, and bank 2 sensor 2 'inactivity' code. You will also need to keep the sensor heater circuits closed to prevent a code as well.
It's a LOT of work for no real results. Modifiying the any part of the exhaust on this truck pretty much only makes it sound different! G/luck Joel
#11 | |
Re: Oxygen Sensors
after some research i noticed a lot of companies make simulators for gm vehicles with obdii think there might be one compatible with the rodeo obdii?
#12 | ||
Re: Re: Oxygen Sensors
G/luck Joel
