Register FAQ Social Groups
Old 11-29-2004, 10:23 AM
ghug ghug is offline
Question left turn growling noise
My 2001 Saturn SL1 makes a growling/buzzing noise when making a left turn above 10 mph. Has anyone experienced this?
Old 11-29-2004, 03:21 PM
Kurtdg19's Avatar
Kurtdg19 Kurtdg19 is offline
Send a message via AIM to Kurtdg19
You might have a worn wheel bearing in your right front wheel.
Old 11-29-2004, 11:46 PM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Re: left turn growling noise
i'll second that
Old 11-30-2004, 12:02 AM
Zgringo Zgringo is offline
The voting has been in favor of a front wheel bearing and seconded, any oppose? then I say look at the wheel bearing for problems.
Albert
Old 11-30-2004, 12:23 AM
mrrob mrrob is offline
How Bout A CV Joint?
How bout a bad Cv Joint?, does it only happen when you make a left hand turn or does it happen, when the car reaches speeds above 10km?
If your getting a constant (HUMMMMMMM) as you pick up speed, it's probably a Wheel Bearing, if it only happens when you turn left and it growls or clicks, it's probably a CV joint.
Good Luck
Mr.Rob
Lic Mech Auto/Truck/Trailer Ect....!
Old 11-30-2004, 09:35 AM
Re: How Bout A CV Joint?
Good Luck
Mr.Rob
It only happens when making a left turn. It begins as soon as turn pressure is applied to steering wheel and stops as soon as turn is completed. I first suspected the power steering but no noise is detected on turns under 10mph. No clicking noise can be detected.
Ghug
Old 12-01-2004, 03:13 PM
383PhoenixAm's Avatar
383PhoenixAm 383PhoenixAm is offline
Send a message via AIM to 383PhoenixAm Send a message via MSN to 383PhoenixAm
As a rule, growling is mostly used to describe problems with bearings. Unless you can describe it as something else, that'd be the first place you should look.
Old 12-07-2004, 08:27 PM
Talking
I replaced the right front wheel bearing and the noise stopped!! Thanks for the input!
Gary
Old 12-08-2004, 12:09 AM
Kurtdg19's Avatar
Gary
Glad to hear that. Hope everything else runs good for a while. If not, there are a lot of knowledgable people here (much more than I am) that are more than willing to help anybody in need. Just think of it as free help, until we all conspire a way to charge everyone.......
Old 12-08-2004, 01:19 AM
yea, feel free to drop in at the saturn section. most of my post are there
