Old 06-13-2001, 09:05 PM   #1
rhombus
rhombus's Avatar
Question I need some help...
:help:
I was putting blue thread locker on my WARN manual hub bolts and broke the head off one tightening it back on!
Do you know if this is a bolt that I have to order from WARN?
Or is this something that I can get at a store locally?
This is such a pain, as I now have to remove everything to try and remove the bolt (which now has some locker on it).
Anyways any help would be great.
Thanks
rhombus
SOXC Member
http://www.soxc.org
rhombus is offline   Reply With Quote
Old 06-13-2001, 10:28 PM   #2
ScottG
If there is nothing left that I can grab on to with vise grips, I usually use a drill and easy-out in that situation. Good luck!
ScottG is offline   Reply With Quote
Old 06-13-2001, 11:19 PM   #3
rhombus
rhombus's Avatar
I will be able to get the bolt out (it might be a pain but I think that I will be able to file it and then you vise grips like you said.
The question that I have is if the bolt has to be a WARN piece (which from VOY I think that it does).
Thanks for the tip.
rhombus
SOXC Member
http://www.soxc.org
Old 06-14-2001, 12:04 PM   #4
ScottG
Here in Houston, I can think of two shops that sell nothing but fastners and would probably have the same studs and nuts that Warn used. The shops I'm thinking of sell nothing but nuts and bolts and primarily supply businesses, rather than sell to the public. You might see if there is some place like that in your area. If you are in a small town, you are probably out of luck.
Getting some detail done, need some help FireFromTheGods Exterior | bodykits | Lighting 0 10-07-2004 12:00 AM
need some help resizing some pics for my sig twdz28 Camaro Discussions 2 09-02-2004 02:50 PM
Need some help findin some parts. slammina98blazer Blazer 5 03-02-2004 09:03 AM
Need some help from some one that can make custom PE parts. Jon MW Car Modeling 1 10-20-2003 11:33 AM
i need some help on some rims jays87 Tires and Wheels 10 05-07-2002 12:32 PM
