Go Back   Automotive Forums .com Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 11-25-2004, 06:28 PM   #1
zippe70
Send a message via AIM to zippe70
Question Need Help setting Boost controller?!?!?!?
Hey I just got the Greddy Profec B-spec 2 i wanted to know if any one knows how I should set the "Gain" and the "Start Boost" I have a sr20det and I want to be around 15psi. When I set the controller it will go up to 15 but then drops off??? Or will not go all the way up to 15, or will just go past it and then back down??? I can’t get a steady boost. I can't get it right let me know if you can help?
Thanks
zippe70 is offline   Reply With Quote
Old 11-25-2004, 07:39 PM   #2
Hit_N_Run-player
Send a message via AIM to Hit_N_Run-player
Re: Need Help setting Boost controller?!?!?!?
ummm, what are you running on your car? i thought the most boost you can run on pump gas is like 14.7psi or something, i dont have turbo so im not sure but...try to set it at like 13 and see how reliable the boost it...sry if this doesnt help im just guessing here..
1988 conquest TSI
-Lots of mods, finally finished WOOT!!
Horsepower sells cars,
Torque wins races!
Hit_N_Run-player is offline   Reply With Quote
Old 11-26-2004, 02:17 PM   #3
R.W.240
Banned
R.W.240's Avatar
Ive heard of the Profec Spec-II having boost spike issues and that may be what your picking up
You set the boost at whatever you want and then set the gain to where the solenoid stays closed for as long as possible without the boost spiking.
R.W.240 is offline   Reply With Quote
Old 11-28-2004, 01:43 PM   #4
LaYzIeNoY
Send a message via AIM to LaYzIeNoY
are you running the stock turbo?
from what i've been told it doesn't work to well past around 10psi, i'm not exactly sure but that may contribute to the problem
LaYzIeNoY is offline   Reply With Quote
Old 11-28-2004, 02:59 PM   #5
logik23
Banned
logik23's Avatar
Send a message via MSN to logik23
A stock S13 SR turbo is effective up to about 13-14 psi.
logik23 is offline   Reply With Quote
Old 11-28-2004, 03:41 PM   #6
Hit_N_Run-player
yeah i think this guy should try and run lower boost and tell us what happens. Maybe he fixed or something cuz he hasnt posted in this thread since the first post so....
1988 conquest TSI
Torque wins races!
Old 12-01-2004, 03:10 PM   #7
zippe70
I just wanted to know how to set the Gain, Set Gain, and the Boost PSI.
I can lower the boost down but i have been told that the car runs good at 15PSI on pump gas And stock turbo.
Old 12-01-2004, 11:44 PM   #8
nissanfanatic
240SX Guy
Send a message via ICQ to nissanfanatic Send a message via AIM to nissanfanatic Send a message via MSN to nissanfanatic Send a message via Yahoo to nissanfanatic
http://forums.evolutionm.net/archive...p/t-75594.html
This is for Evos but it is the same.
-Cory
1992 Nissan 240sx KA24DE-Turbo: The Showcar
Stock internals. Daily driven.
12.6@122mph
496whp/436wtq at 25psi
nissanfanatic is offline   Reply With Quote
Old 12-02-2004, 05:01 PM   #9
mynismo
yada yada yada
Send a message via AIM to mynismo
yes, but it doesn't hold it.
t25's will only hold 11.5 lbs at redline. the problem isn't with your boost controller, the problem is your tiny turbo. look at the dyno in my sig, and notice how the tq drops off up high. tq is a direct relation to boost.
438whp / 373tq - 11.9 @ 126
mynismo is offline   Reply With Quote
