Go Back   Automotive Forums .com Car Chat > Buick > Roadmaster
Old 05-21-2004, 07:21 PM   #1
sopranomobile
Unhappy keyless entry
Does anyone out there have instructions for programming a 1995 roadmaster?
sopranomobile is offline   Reply With Quote
Old 05-21-2004, 10:07 PM   #2
tman
Pimpin' ain't easy
tman's Avatar
Send a message via AIM to tman
Re: keyless entry
Next time you post a roadmaster question, put it in the roadmaster forum, not the century
tman is offline   Reply With Quote
Old 11-08-2004, 06:51 PM   #3
tinglygravy
Re: keyless entry
This is the roadmaster forum isn't it?
tinglygravy is offline   Reply With Quote
Old 11-08-2004, 08:44 PM   #4
tman
Pimpin' ain't easy
tman's Avatar
Re: keyless entry
It was in century, I kindly moved it to roadmaster, so it would be in the proper place
Old 11-08-2004, 09:39 PM   #5
tinglygravy
Programming info!
1. In the trunk, on the lesft side find a black plug that goes to nothing Its just hanging there. you will se a white stripe on the black wires coming off of it.
2. just stick a small screw driver into the plug making sure that it touches the two small pins inside the plug.
3. holding th screwdriver in the plug you will hear the door locks and/ or trunk lock click.
4. do not remove the screwdriver and when you hear the clicks press one of the buttons on your remote sweetch and you will hear a lock click that means you just activated teh remote....
5. if you have 2 remotes press a button on the 2nd remote switch at this time and you will hear a lcok click meaning that remote will now work too.
6. remove screwdriver and test your remote switches.
