Old 09-13-2004, 06:08 PM   #1
thepig333
Send a message via AIM to thepig333
Question 89 accord gas guage not responding
I got an 89 accord, and I get no response out of the fuel guage. Do you think this could be the sender? If so then where in my car could I find the sender? If you don't think it is the sender, then what? I am stumped and I can't find anything in the haynes book about it.
thepig333 is offline   Reply With Quote
Old 09-14-2004, 01:41 AM   #2
mpumas
Re: 89 accord gas guage not responding
The easiest way to troubleshoot a gauge problem is to find the sensor which is attached to the top of the tank, probably on the right side in the trunk or under the back seat. THere is a plastic cover covering the sensor. Remove the cover, disconnect the connector and short the terminals on the cable. Turn on the key. If your guage slowly goes to full, the problem is the sensor.
mpumas is offline   Reply With Quote
Old 10-14-2004, 05:27 PM   #3
thepig333
89 accord fuel system help needed
OK I have changed the gas sensor completely out, as well as my fuel pump and my fuel relay. Does any one else know what this may be. Also My car has a problem where it revs up to around 3000 rpm, when I am stopping or sitting still at like a red light or something. I have no clue what this could be. I have changed my throttle cable, and checked each of my injectors. Please help me...
Old 10-14-2004, 05:35 PM   #4
henrymv
Have ytou checked for a vacuum leak in one of the hoses? Withthe hood up and listening closely to the engine do you hear any hissing noises???
So was the problem with the gas gauge the sensor???
henrymv is offline   Reply With Quote
Old 10-14-2004, 06:06 PM   #5
thepig333
no the gas guage is still not working
Old 10-14-2004, 06:08 PM   #6
henrymv
i take it the other gauges are working properly? Have you check the electrical connection that leads to teh gauge?
Old 10-14-2004, 06:14 PM   #7
thepig333
yes the other guages work fine. No I haven't checked the electrical connection. I do not know where that is. The only thing I have checked electrical is my fuel sensor. Also I do not hear any hissing sound other than my intake.
Old 10-14-2004, 06:15 PM   #8
henrymv
the electrical connections start behind the gauge and go toward the sensor
Old 10-14-2004, 06:17 PM   #9
thepig333
so do I need to remove my dash?
Old 10-14-2004, 06:18 PM   #10
henrymv
yep
Old 10-14-2004, 06:19 PM   #11
thepig333
well that sucks. do you have any suggestions about my car revving so high?
Old 10-14-2004, 06:23 PM   #12
henrymv
there is a vacuum leak somewhere....get a can of ether or starting fluid and lightly mist around the hoses, while the engine is running. When you hear the engine increase RPM's then you have a bad hose or a crack in ahose somewhere or you can also have a disconnected hose or slighty disconnected hose.
Old 10-14-2004, 06:44 PM   #13
thepig333
ok I have pratically sprayed everything in my engin and no change in rpms. any other suggestions?
Old 10-14-2004, 10:54 PM   #14
mpumas
In my last post I told you how to determine if it was the sensor or wiring/dash guaqe. Did you do the test and what were the results if you did?
Old 10-14-2004, 11:20 PM   #15
thepig333
I have not taken my dash apart yet. I will try to do so by the end of weekend. I did try spraying the engine vaccum hoses with ether and got no response from vaccum leaks. Do you have another suggestion on how to test to find the leak?
