Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Talk
Old 09-24-2004, 07:59 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
trick flow intake/sender location
I have a trick flow track heat intake. Does anyone know if there is more than one ECT sender location on it, off hand. I think that may be my rich problem, cause right now its not even hooked up.
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 09-24-2004, 11:41 PM
eillob's Avatar
eillob eillob is offline
Re: trick flow intake/sender location
Hey stang racer what kind of numbers are you running in the 1/4? Your set up is a lot like the one I am working on for my car.
Ported Cobra Intake, Ported & polished Windsor Jr heads, K&N, Vortech s-trim, 90mm Lightining mass air meter, 70mm throttlebody,1.7 roller rockers, BBK Long tube headers, offroad H-pipe, Crane cam, main cap girdle, 40 series flowmaster, 3.73 gears, MSD ignition, CGS subframes, A9L PIH kit, SCT custom burned chip, 42lb injectors, 190lph fuel pump, T rex and fuel pressure regulator, AFCO racing radiator
(If it doesn't scare the Hell out of you it isn't fast enough)
Old 09-26-2004, 07:40 PM
SVTcobra306's Avatar
SVTcobra306 SVTcobra306 is offline
Haven't seen one in person, but if it will directly bolt on to an SN95 5.0 then it has a hole on both sides of the front of the intake manifold-SN95's have a sensor/fan switch, and a sending unit.
There may also be plugged fittings in the rear of the intake, too.
Beware, there should also be a hole for an air charge temp sensor (for fox-bodies) in it also...
1994 SVT Cobra. 306, Ported GT-40X's, Crane 2031, NX Wet Kit (100 shot for now),TKO 500, TwEECer R/T, and all the bolt-ons.....
http://www.cardomain.com/id/mccobra94
1995 F-150 SC/4X4 351W/E4OD, K&N, Custom Exhaust w/Flowmaster.
Freedom Isn't Free.
Old 09-26-2004, 11:10 PM
I got it. I lucked out cause the aftermarket chrome water neck i have has a pre-tapped thread(was plugged) for a sender, which I never even realized till now. So all I had to do was extend the signal wire a little to reach it.
Can someone with a fox 5.0 tell me what color the signal wire is for the ECT. I just wanna make sure it was the right wire that I had wrapped up before. Thanks all.
Eillob, I have not run it yet. I havent even gotten it road worthy yet really. I am, however, expecting high 11's or low 12's, tuned w/ slicks. What exactly are you working on?
Old 09-26-2004, 11:26 PM
eillob's Avatar
Im getting some quotes right know for a 331 or a 347. Most places are giving me bids of about $5,000. Thats just for the motor. DSS quote was about $5,300 with a X303 cam and TFS heads. I don't know if I should go that route or just get a 347 short block from Ford motor sports and put my own combo together. Any suggestions?
Old 09-26-2004, 11:30 PM
It really depend on what you wanna do in the future. If you plan on going big, I'd go w/ either a CHP or a DSS shortblock and do the rest yourself.
Old 09-27-2004, 05:34 PM
351wStang's Avatar
351wStang 351wStang is offline
You could go with a DSS short block. Have it machined for a hydro roller cam and lifters. Run AFR 185's, 10:1, Performer RPM intake, and have a quick street car.
1969 Cougar
357w & TKO - 475hp
Old 09-27-2004, 06:13 PM
Most of DSS's short blocks are roller setup anyway, since a 5.0 is that way from the factory.
I agree, use their shortblock, but shop around for the rest and build yourself a mean motor.
Don't spend 5 grand on a motor and screw it all up with an alphabet cam. Custom grind, all the way.
Freedom Isn't Free.
Old 09-27-2004, 08:14 PM
eillob's Avatar
Re: Re: trick flow intake/sender location
Who do I see for a custom grind cam? I've made up my mind Im definately going with AFR heads. Check out the new AFR competition head. http://www.fordmuscle.com/archives/2...arch/index.php
Old 09-27-2004, 09:54 PM
Flow Tech Induction- Ed Curtis is a wizard with smallblock Fords.
Crane and Comp do custom grinds also...
Freedom Isn't Free.
Old 09-28-2004, 12:23 AM
Anyone know? Also, does it matter which side of the thermostat the computer takes the coolant temp reading from at all. I dont think so, but I wanna be sure.
Old 09-29-2004, 12:00 AM
bump
