Go Back   Automotive Forums Car Chat > Nissan > Altima
Old 12-07-2004, 02:58 PM
Pinmiser Pinmiser is offline
Send a message via ICQ to Pinmiser
Question 93 Altima Electrical Problems!
Hello,
I have been reading posts for a while. Hoping to see if anyone else had already asked the questions I have. No real luck so far. So here I go, I hope someone can help me.
My son was just given a 93 altima gxe automatic. The alarm had been removed and slowly elect. problems started. At times you can put the key in and the car will not start, once started runs fine until you shut it off. I can hear a switch near the fuse box under the dash clicking when try to start. Radio will work only when you turn the key on, then hit the door frame (either side of the car). And the power windows will not work, even though can hear the switches in the door frames clicking when you try to roll them up or down. If anyone had any suggestions or ideas where on the car I can find this short, would be greatly appriecated! Could it be in the ignition switch?
Thanks.
Old 12-07-2004, 04:12 PM
k3smostwanted's Avatar
k3smostwanted k3smostwanted is offline
Z Cars Fanatic
Send a message via AIM to k3smostwanted
wow...that sounds wierd. probably when they pulled the alarm out they pulled a wire loose from the ignition or maybe a ground. but i would have no idea where to look. i would take it back to whoever removed it and ask them where the alarm was. then start looking in that area. good luck...i hate electrical problems.
ZedEx Crew Member #4
Old 12-08-2004, 09:09 AM
x1gary's Avatar
x1gary x1gary is offline
Send a message via AIM to x1gary Send a message via MSN to x1gary Send a message via Yahoo to x1gary
Check the dealership, for a new wire harness and check out the price of installing it, that would be the best way to go ... you could prolly also go to the local mechanic, and have then look around for the wires that are loose.
Altima G
Old 05-14-2005, 06:33 PM
nissan D nissan D is offline
Re: 93 Altima Electrical Problems!
the stereo was taken out of mine then the windows on pass side stopped workin. might b water got in black box it did in mine , now my speedo is not working. check for water leaks at pass side door
Old 05-17-2005, 04:29 PM
sutley153 sutley153 is offline
wow, i'm getting exactly the same problem. I left my altima on the side of the interstate today because of it. If it doesn't start, will have to tow to mechanic.
Old 05-17-2005, 05:51 PM
wonword wonword is offline
Send a message via AIM to wonword
I had a problem with the alarm, sometimes it would unlock the doors and sometimes it wouldnt. I just moved a ground wire from the body to the engine ground and it seems to work fine now, dont know if it works fine becuz of that or just because alot of stuff was shaken when I took my tranny off.
94' Nissan Altima SE
K&N High Flow Air Filter
Greddy St Exhaust
OBX Header
Short Throw Shifter
Extreme Performance Clutch
68' AMC Abassador
Chevy 350
TH 350 Tranny
Headers
Dual Exhaust
1999 Suzuki GSX-R 600
Yellow/Black
Yoshimura Exhaust
http://members.cardomain.com/wonword
Old 05-18-2005, 04:33 PM
fatjoe99 fatjoe99 is offline
check where the sound is coming from. There is a possible shortage.
