Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 06-25-2004, 10:02 AM
woodsonj3 woodsonj3 is offline
95 timing belt question
Does anyone know what the real recommended replacement interval is? I had it replaced at around 70,000 miles because the dealer was running a special. The car now has about 155,000 on it. The engine is the 1.8 liter (7A-FE I think). Thanks.
Old 06-25-2004, 11:58 AM
gator2764 gator2764 is offline
I believe the change should be done every 70K. You should be able to hear it slapping slightly if it is stretched a little. I went 90K on the second one I had put in my camry. I also had the water pump replaced then.
Old 06-25-2004, 11:44 PM
Erndog1369 Erndog1369 is offline
Smile
The recommended interval is 60,000 miles. I've only seen a few Corolla belts fail in my 8 years as a Toyota technician. It's a good opportunity to check the waterpump and cam and crankshaft oil seals though, so doing it every 60k isn't a bad idea.
