Go Back   Automotive Forums .com Car Chat > Ford > Taurus | Taurus Wagon
Old 01-29-2004, 10:47 AM   #1
treeman769
Send a message via AIM to treeman769
Angry 98 taurus not starting
occasionally my car will not start.motor turns over and catches but then dies.if i wait 20-30 min.then it will start.so far only does it when its warm out.any ideas or suggestions appreciated.
treeman769 is offline   Reply With Quote
Old 04-01-2004, 11:40 AM   #2
eyepatchguy
Re: 98 taurus not starting
I AM HAVING THE EXACT SAME PROBLEM!!! did you ever get it fixed or can someone please help?
eyepatchguy is offline   Reply With Quote
Old 06-16-2004, 10:05 PM   #3
Twillmann
Angry
I am having the same problem with my 99 Sable, did either of you guys find the problem?
Thanks
Todd
Twillmann is offline   Reply With Quote
Old 06-17-2004, 12:34 PM   #4
Dan_in_WA
Send a message via AIM to Dan_in_WA Send a message via Yahoo to Dan_in_WA
How many miles have you all got? Clogged fuel filters, maybe? Sounds like it may be related to fuel pressure.
Try having the codes read; the Autozone will do this for free. Even if there are NO codes, this in itself is useful information.
Dan_in_WA is offline   Reply With Quote
Old 06-17-2004, 02:15 PM   #5
Twillmann
Thanks Dan, We replaced the idle control moter when it first happened, and it didn't do it for 2 months, No codes then, no codes now. If the fuel filter was clogged, I would think it wouldn't ever start, But if you let it sit for 20-30 min, it starts up and runs great. I am leaning towards a fuel problem too, just wanted to see what everyone thought before I dropped the tank to replace the fuel pump. Although, why would you only have problems during hot starting? If it was a fuel pump, it seems like you would have problems other times also?????
Todd
Old 06-17-2004, 02:36 PM   #6
Dan_in_WA
For what you'll pay a shop, you can buy a decent pressure guage and check your fuel pressure and find out for sure what's happening.
If the pressure is initially high, then drops as the engine runs for a moment, that would indicate a clogged fuel filter. The gas just can't get through it fast enough.
I'm real curious to see the difference in fuel pressure between cold and hot start situations. That will get you pointed in the right direction.
Old 06-17-2004, 02:46 PM   #7
Twillmann
After it starts hot, you can run at wide open throttle without any loss in power, It seems like something that only works during starting...
Todd
'97 Ford Taurus Not Starting bronny Taurus | Taurus Wagon 5 12-08-2005 11:11 AM
92 Taurus not starting Raheamd Taurus | Taurus Wagon 3 03-30-2005 03:10 AM
91 Taurus not starting IkebotXP Taurus | Taurus Wagon 1 01-16-2005 10:23 AM
94 Taurus not starting Trump900 Taurus | Taurus Wagon 3 01-14-2005 08:14 AM
88 Taurus not starting-->sporatically kawdude Taurus | Taurus Wagon 6 10-09-2004 08:03 PM
