Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 10-30-2003, 01:23 PM
RB25240kouki's Avatar
RB25240kouki RB25240kouki is offline
Send a message via AIM to RB25240kouki
Lift gate lock broke
Hey all. I am posting a question for my Mom. She has a 99 Jeep Grand Cherokee Laredo. The lift gate lock makes a high pitched grinding sound when the lock is activated to either lock or unlock. The liftgate works most of the time but sometimes the lock remains locked intermintenly. When it makes no sound at all the lock does not function but we dont know if the motor is still turning because the sound of the other door locks drowds out the sound. The problem was fixed by a dealership a few times while it was still under warrenty, but the problem has returned again. I was wondering what exactly was broken and how to get that part. Also I was wondering if anyone other that jeep made that replacement part... Like one that will last a bit longer!. Well anyways just shoot me with a respons if anything comes to your mind. THANKS! (PS. look for my post about the stock stereo tweeters *infinity gold*)
Old 11-17-2003, 03:44 PM
cac5451 cac5451 is offline
Lift Gate Door Lock
Your problem is the Power Door Lock Actuator. I have the same problem with my 2000. The real issue is that the factory part is a piece of garbage and is a common item to fail. I would suggest taking it to an aftermarket shop and finding another part that will perform the same function and fit, but use a different vendor. If I find out more on mine, I will let you know.
Old 06-11-2004, 01:20 PM
pincheyloveclaw pincheyloveclaw is offline
Send a message via Yahoo to pincheyloveclaw
Re: Lift Gate Door Lock
Did you ever find a non-OEM replacement part for this? I have a 2000 Grand Cherokee with the exact same problem and I refuse to let the dealer rip me off on that problem again!
Old 06-12-2004, 05:07 PM
my mechanic brother fixed it (again) but im not sure if he used non oe parts... he probably did. If it breaks again then we will use somthing more reliable.
1989 GTUs
JDM Turbo II motor
Custom exuast: gutted pre-cat, high flow 3" cat. Ypipe into two 2.5 inch pipes with N1 sytle cans.
Walbro 255 fuel pump
Pivot headlight controller
More mods to come
Happy Rotoring
Old 06-16-2004, 06:41 PM
I think I got it now.
Hey guys,
Just to let you know. I ended up talking with a friend of mine at a Jeep dealer and he said that Chrysler used plastic gears in the actuators and they wore quickly causing this problem. I bought some new actuators from the dealer that have now been retooled to have a metal gear instead of the plastic one. They are dealer replacement parts but since they changed the gear material, they should last a lot longer. Mine have been in place for quite some time now and so far so good. Make sure to ask the parts guy to make sure you get the actuators with the metal gears. Good luck.
Old 06-16-2004, 06:42 PM
Re: Re: Lift Gate Door Lock
Hey guys,
98 Astro electric lock, lighter, rear lift gate. leatherman M Bodies 3 09-09-2007 12:15 PM
gate locks locking but vibrating bad. grizz442 Grand Cherokee | Grand Cherokee SRT8 0 04-06-2007 03:38 PM
My Lift Gate Lock Doesn't lock... perry8685 Rodeo | Passport | MU 3 06-16-2005 11:45 PM
lift gate lock brainyass Cherokee 1 03-25-2005 03:03 AM
Lift-gate lock sbolt? tgrudzin Cherokee 1 09-20-2004 10:49 PM
