| Wheels/Tires/Suspension All the handling help you need. No matter what Honda/Acura you drive. |
do you lose horsepower going from 17's to 18's??
The guy in my local auto accesories store told me that if you go 18s you lose some horsepower.. i was just wondering if anyone else has ever heard of this?
Re: do you lose horsepower going from 17's to 18's??
yes, The larger the diameter, the more the vehicle has to work to make them turn. Going up just an inch wouldn't hardly be noticable. You can always just get a slightly lower profile tire to make up the difference though
I agree...
Not necessarily. If you use low profile tires and keep the same overall diameter as original it will probably be the same. If the wheel is a lighter aluminum wheel and there is less rubber then the overall wheel and tire combination will be lighter than a stock tire with all that rubber. Using a low profile and keeping original diameter will also keep the speedo in the right spot.
![]() Join Date: Oct 2003
You would not loose horsepower by plus sizing since the aspect ratio will change to keep you at the correct O.D. . It's only when jumping up in O.D. that you run into problems. It has the same effect as changing your gear ratios on the back end of everything.
Grant Your personal contact at The Tire Rack 1-877-522-8473 ext# 313 fax# 574-236-7707 email: [email protected]
Listen to Grant, he is the man
#7 | |
increase in diameter will cause a loss in power. weight does not matter. going up in tire diameter is like gearing up (higher gears). Smaller diameter is like gearing down (lower gears/higher numerical value). Trust me, when all you do is build vehicles for off-road, you will realize fast when you're running 44+" tires!
#8 | |
haha
#9 | ||
Re: Re: do you lose horsepower going from 17's to 18's??
#10 | |
rim size has nothign to do with it, because the tire gets smaller as the rim gets bigger. the weight is the thing that effects it, so if your wheels and tires weight 25lbs at each corner with the 17's but weight 30lbs at each corner with 18's then yes your losing horsepower to the ground, but not at the crank ofcourse
1989 RX-7 TII --- Just got rebuilt and street ported RB 3" dual exhaust, BNR stage 1 modified factory turbo, FCD, S-AFC II, 720cc secondaries, Aftermarket Turbo inlet duct w/K&N, Hawk HP+ pads HKS Blow-Off Valve, Stainless brake and clutch lines |
#11 | ||
So...if the tire gets smaller (I'm assuming you mean diameter) as the rim gets bigger, um...what happens when you go from 14" wheels to 27" wheels ?? Is the tire completely gone by then. Weight does play a big role on torque (at the wheels of course) but it wouldn't be noticable going from 17's to 18's. That's like when people install little gadgets on their cars, add 5 or so horsepower or torque, and say that they can feel the difference Last edited by goinbig; 05-13-2004 at 12:52 AM. |
#12 | |
Haha, good point goinbig
#13 | |
They say they can feel it, because they want to believe that it really made a noticeable difference, the mind can do many extraordinary things
#14 | |
ya, I always like it when people say that they can feel the increase in horsepower, when torque is the thing that you can actually 'feel'. Torque is what makes the wheels spin and the car go.
Then, people come on here saying that they can feel this "horsepower," and how much they have gained by putting on lighter wheels, when I can almost bet they didn't put the car on a dynomometer to actually prove it. |
#15 | |
so wait, are you suggesting the wheel weight has nothing to do with acceleration, and speed and the such - that wheel weight has no effect on performance?
