Re: Front End Camber Problem After Rebuild
Originally Posted by Buck Naked
After rebuilding the front end (balljoints, bushings, tie-rod ends, idler arm, and springs) I have a serious positive camber problem (top of wheels lean out). I believe the stock spring rate for the car is 380 lbs, but I was unable to locate a stock set and used heavier springs at 550 lbs. The car is a 70 vette with a small block and as far as i know uses much of the same front end components as the bb optioned cars (except for spring rate). I have made the maximum adjustment to camber by shimming the upper control arms to the point where there are but a few threads left on the cross-shaft bolt. That helped a little, but there is still way too much positive camber. Im guessing the problem is the springs, but have been assured (by the vendor) that they can be used on the small block car. Any help is appreciated.
If you installed heavier rate springs, that would raise the front end and cause a negative camber issue.
If this problem occurred after your rebuild, I would take a closer look and see if something is installed incorrectly.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
