Old 05-03-2004, 01:10 PM   #1
godfather23
godfather23's Avatar
HOW to put a model in a display case onto a wall?
Iīm thinking about putting all my models into separate display cases and then hang those onto a wall. The problem is that I canīt figure out a way to make those modells stick to the display case floor so that they donīt fall when I put the modell onto the wall eventually. I donīt want to put a screw into the chassis of the modell.
Please advise or give me some hints to solve this!
Recently finished Projects:
Porsche 911 Carrera RS 3.0
Current Projects:
godfather23 is offline   Reply With Quote
Old 05-03-2004, 01:13 PM   #2
pre98zetec
pre98zetec's Avatar
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: HOW to put a model in a display case onto a wall?
What? Are you talking about the display cases falling down? If so, Use a shelf?
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
pre98zetec is offline   Reply With Quote
Old 05-03-2004, 01:14 PM   #3
dag65
dag65's Avatar
Send a message via Yahoo to dag65
How about a small piece of double sided tape under each wheel?
dag65 is offline   Reply With Quote
Old 05-03-2004, 01:20 PM   #4
nervestrikes
nervestrikes's Avatar
How about drilling a small hole in one side of the clear display cover that a nail, hook, etc. can fit through, but be sure not to crack the clear plastic cover. Next because it is on display crazy glue the black base to the cover so it never comes open. Now you just hook it on the was like a picture. Done a buddy of mines like this and it looks great in his rec. room.
nervestrikes is offline   Reply With Quote
Old 05-03-2004, 01:31 PM   #5
dag65
dag65's Avatar
If by crazy glue you mean Super Glue or CA that is a bad idea, as the glue gases out it will fog all the windows on the model as well as make all the fingerprints thtat might be there permanent.
If you actually read the post he is trying to figure out how to keep the model from sliding all over - not how to hang it on the wall
Old 05-03-2004, 01:34 PM   #6
Sk8er6811
Banned
Sk8er6811's Avatar
Send a message via AIM to Sk8er6811 Send a message via MSN to Sk8er6811
tape is def. the best way to go, or use a lil bit of blue thumbtack
Sk8er6811 is offline   Reply With Quote
Old 05-03-2004, 01:35 PM   #7
dag65
dag65's Avatar
Re: Re: HOW to put a model in a display case onto a wall?
Fun Tack dooohh I forgot about that, great idea
Old 05-03-2004, 02:52 PM   #8
nervestrikes
OOOH, I thought he was looking for something else. Curious how do you know there will be gas that would fog the windows. I never thought about that.
Old 05-03-2004, 03:01 PM   #9
dag65
dag65's Avatar
Thats just the nature of CA, Law Enforcememnt Agencies have used a similar method to reveal finger prints for years. And I think it was not too long ago that someone here on the board glued a bunch of pieces on a model to complete it ( used CA ) and put it in a display case and set it on the shelf only to return to a disaster the next day.
Old 05-03-2004, 03:34 PM   #10
willimo
Sweet, sweet tiny Hondas.
The best thing, I would think, would be that double sided foam tape 3M makes. It is very strong, but easily removable. Alternatly, if you want a classier solution that won't lift the wheels 1mm off the case floor would be to use a hook. Either form your own or get some small wire hooks that are bent 90 degrees (not a C shaped hook). Drill holes in the floor inboard of the lowest point on each wheel (or two of them). Then put the hook through the hole, with the 90 bend pointing out, and hook the wheels under them. This may take some finagling, but it's doable, and the best would be to use minature threaded rod and nuts, so you can tighten the hooks down and hold the car in place tightly. This won't require any modification of the model, and if you paint the hooks flat black, they will be invisible.
Old 05-03-2004, 03:48 PM   #11
Macdaddy4738
Send a message via AIM to Macdaddy4738
drill a hole in the bottom of the display case. Run a length of wire through the hole...around the axle of the model and back through another hole drilled in the bottom of the case.
Macdaddy4738 is offline   Reply With Quote
Old 05-03-2004, 04:21 PM   #12
jswillmon
jswillmon's Avatar
Send a message via AIM to jswillmon
I have a few "Johnny Lightening" display cases that have a few holes for just this reason in the base.
The Name's Jesse!
**Click the pic for my latest build, Daytona Blue 350z**
jswillmon is offline   Reply With Quote
Old 05-03-2004, 04:26 PM   #13
godfather23
Wonīt work, tried it, not really sticky enough. I really need something working. I donīt want to repair my babies every week, because they re falling of the case floor.
That sounds like a great idea. I will give that a shot. Thanks a lot. If that doesnīt work, Iīll go with the axle solution.
Current Projects:
Old 05-03-2004, 06:48 PM   #14
soldsep
is the case floor not leveled? i dont understand how they are sliding around.
soldsep is offline   Reply With Quote
Old 05-03-2004, 06:52 PM   #15
Sk8er6811
Banned
Sk8er6811's Avatar
me either
