Go Back   Automotive Forums Car Chat > Pontiac > Grand Prix
Old 03-14-2004, 12:20 AM
mandjsstuff mandjsstuff is offline
SES codes PO 108 and PO 123
Last night my Service Engine Light came on. Went to Auotzone ready to buy whatever I needed. They ran the codes and the guy basically said he had no clue and didn't want ot sell me anything because my codes indicated high inputs. They were (1) P0108** Manifold Absolute Pressure/Barometric Pressure Circuit High Input and (2) P0123** Throttle/Petal Position Sensor/Switch A Circuit High Input. I also have noticed that at times when I hit a bump my radio and message center blink off. My inclination is to pull the computer out and clean contacts and hope. Another problem that may be related is a banging noise from the rear speakers with my aftermarket Pioneer CD. I have noticed it seems affected by the weather (mid 30's-40's) and accerlation. Suggestions would be great.
Old 03-14-2004, 09:18 AM
dppavlis dppavlis is offline
What mods have you done?
Old 03-14-2004, 12:00 PM
Re: SES codes PO 108 and PO 123
Engine is a bone stock 3.8 base model GT.
The radio is a Pioneer with PAC control for the steering.
I've installed a remote starter with the T harness from Bulldog security. The T harness eliminates the need to cut the wiring harness as it splices between the harness that plugs in at the steering column. The only splices are for the trunk release button, and the running lights.
Hope this helps.
Mike
Old 03-18-2004, 03:20 PM
Dwilko Dwilko is offline
Yours might be a little different, but I just got the P0108 code. Replaced the M.A.P. sensor (took all of 10 seconds), and POOF, SES light gone.
Old 03-18-2004, 05:10 PM
Well I decided before I'd take it to the dealer, I'd clean a few connections and see what happened. I cleaned the contacts to the battery, the main fuse relay and the ground going to the body from the battery pigtail. I also unplugged and re plugged the computer module. The SES code stayed on for about 20 minutes and has been gone for about a 1000 miles.
Maybe its a simple cure.... I hope.
Mike
SES Codes P0420 and P1404 capot F-Body Problem Diagnosis 12 03-17-2010 01:29 PM
2006 Saab 9-5 codes 1301 and 300 nero11 9-5 0 08-06-2009 09:45 PM
2002 Transmission Codes P700 and P740 rjs0421 2nd Gen 00-05 0 08-04-2009 10:28 AM
SES code help redfox3369 Venture 1 04-09-2009 01:42 PM
P0753 SES Code and Fuel Gauge Trouble reiserk Blazer 13 07-28-2005 11:00 AM
