Go Back   Automotive Forums Car Chat > Nissan > Altima
Old 03-06-2004, 07:55 PM
kisswahili kisswahili is offline
Firewall hole
im trying to install an amp in a 98 nissan altima but i cant find a hole thru the firewall to run my power wire...anyone know exactly where it is?
Old 03-06-2004, 08:30 PM
sleeperalty sleeperalty is offline
Send a message via AIM to sleeperalty Send a message via MSN to sleeperalty
i had to drill a new hole. there really isnt one already there for you to use
Old 03-06-2004, 08:45 PM
Re: Firewall hole
where exactly did u drill it...i run the power wire temporarily under the car and into the car right under the drivers seat...how safe do u think that is?
Old 03-06-2004, 09:14 PM
BP2K2Max's Avatar
BP2K2Max BP2K2Max is offline
Send a message via AIM to BP2K2Max
Re: Firewall hole
i have a maxima so it may not work for you, but i ran it under the fender then through the molding on the door, right next to the hinge. i didn't wanna drill into my car. it's been working fine for the last 6 months and there is enough room so that the wires don't get crushed.
BP's Rides;
- 2005 Kawasaki Ninja ZX6R- Mods: ECU Jumper, Akrapovic Slip-on, Power Commander III, 8000K HID's.
- 2K2 Maxima 6 Speed-Mods: Advanced Timing, Cattman Cat-back Exhaust, H&R Springs, Tokico Illumina Struts, Konig Theory 19" Rims.
Old 03-06-2004, 09:33 PM
Re: Firewall hole
do u have pics
Old 03-07-2004, 10:41 AM
BP2K2Max's Avatar
Re: Firewall hole
it gets tucked under the plastic kick shield right after it comes around the molding.
there's about an inch of space between the door and the frame when the door is closed. the wire will be fine.
BP's Rides;
Old 03-07-2004, 01:13 PM
Re: Firewall hole
thanks thats great!!!!!!!!!!!!
Old 03-07-2004, 04:42 PM
Re: Firewall hole
what gauge wire is that cos in runnin 4 gauge
Old 03-07-2004, 07:34 PM
Re: Firewall hole
that is dangerous to do. you never want to run a power wire in any area where there can be constant friction (a door hinge area for instance). after awhile, the constant opening and closing can rub the insulation off the wire and that can cause problems.
as for the altima, i drilled a hole under the power booster by the brake master cyl. I dont have any good upclose shots of it, so i dont really know how to show you
Old 03-08-2004, 12:55 PM
BP2K2Max's Avatar
Re: Firewall hole
the wire never comes in contact with the hinge or any other parts. you can't tell from the pictures but the wires fine. i can see why it looks like it'd get caught but up close it's fine. I contemplated how to run it for a good amount of time and weighed my options, i'm happy with how i have it. plus there is a little slack in the picture that isn't there under normal conditions, it usually sits flush in the indentation above where the door hinge is mounted. look where the fender is and just picture the door being closed and the wire running directly behind the molding. i totally disagree that it's unsafe.
and that wire is 8 gauge.
BP's Rides;
Old 03-08-2004, 04:54 PM
Re: Firewall hole
cos 4 gauge will definately not go through there..geuss i will just have to get a hole drilled
