Go Back   Automotive Forums .com Car Chat > Pontiac > Grand Prix
Old 02-23-2004, 06:09 PM   #1
second2none
Send a message via AIM to second2none Send a message via Yahoo to second2none
Unhappy stock remote
Need help! Stock remote will not open/close door locks, or trunk .
It is not the battery. Have second remote, it does not respond to it either. Help if you can. Thanks
second2none is offline   Reply With Quote
Old 02-24-2004, 01:27 PM   #2
solideo7
solideo7's Avatar
Send a message via AIM to solideo7
Re: stock remote
Maybe they need to be reprogrammed. You may want to try that.
2000 Silvermist Grand Prix GT
Thrasher CAI, RT Cat w/3"downpipe, U-bend delete, ZZP Rockers, ZZP 180 T-stat, ZZP Stage I HVTB, ZZP HVIMI
solideo7 is offline   Reply With Quote
Old 02-25-2004, 10:31 PM   #3
wbs97gp
Re: stock remote
Try to syncrhonize the remote to your car.
1. stand next to the car, or in the car and hold down the lock and unlock buttons at the same time for about 30 seconds.
This should synchronize your remote to the car receiver.
2. If the above didn't work, you will need to re-program your remotes to the car. Do a search on programming the remotes, there is a thread on this board with those instructions already. When you find it, print them out, you will not be able to remember them.
Good luck
wbs97gp is offline   Reply With Quote
Old 02-27-2004, 10:52 AM   #4
kilroypr
kilroypr's Avatar
Send a message via MSN to kilroypr Send a message via Yahoo to kilroypr
Re: stock remote
I would do the reprograming anyway. After you find the thread, the process itself is not that complex. If that does not work then most probably would be the reciever that is located behind the trip computer on the dash board
kilroypr is offline   Reply With Quote
chime indicating keyless remote error - 2003 Pontiac Grand Am Jcolli06 Grand AM 1 02-18-2009 07:37 PM
remote start using stock remote Formulaace Silverado 2 12-12-2004 03:02 AM
Programming stock Remote for 02 Cavalier (keyless entry)? dietz4ibanez Cavalier 1 07-03-2004 08:44 PM
Stock Remote Keyless Entry Installation dabomb4097 Century 2 06-28-2003 05:23 PM
