Cylinder Compression Test Results....need some help
I'm lookin at buying a 99 Jeep TJ Sport V6 4.0L. I got a full mechanical inspection done this morning with the compression test but I myself am not really sure on if they are good or not. Unfortantly and apparently I could not talk to the mechanic who done them cause they were to busy. Fair enuf. Here they are....if anyone knows about this stuff could ya give me a reply tellin me if these numbers are excellent....good.....hopefully not horrible:
Cylinder 1 - 155 lbs Cylinder 2 - 155 lbs Cylinder 3 - 152 lbs Cylinder 4 - 155 lbs Cylinder 5 - 155 lbs Cylinder 6 - 152 lbs Thanx for anyhelp anyone can give. The only other thing I was conserned about in the mecahnical was a not about the rear brake adjusters being seized. Because of that they are unable to remove the drums??? Is this a serious issue as far as repair costs go. I'm going to have it fixed ASAP however I just wonderin if anyone knew an estimate on what this could cost. |
Re: Cylinder Compression Test Results....need some help
The compression test doesn't show a whole lot of cylinder-to-cylinder variation, which is good. The measured figures are in about the range where I would normally expect them to be, although I don't know anything specific about your engine.
Take a normal rear brake job price (I've never paid someone to do it, so I don't know what they'd charge, guess= $200) and add about $100-$150 for additional labor to get the stuck drums off.
Come on fhqwhgads. I see you jockin' me. Tryin' to play like... you know me... |
as for the rear brakes, the entire bag of hardware for the rears incl the adjusters is about $30-40 and 15-20 minutes of someones life to install it, Id ask that this be fixed as part of the deal, a 99 still is costing a pretty penny, in todays economy they can fix it and still make $$ as for removing the drums, and drum puller will get em off even if it breaks the keepers (part of that bag of hardware) |
