Go Back   Automotive Forums .com Car Chat > Pontiac > Fiero
Old 04-26-2004, 12:01 AM   #1
Ragtop_Renegade
Ragtop_Renegade's Avatar
The 2M4 comes home!!
Friday, title in hand, I FINALLY brought the Fiero home. And so the convertible project begins... My first step is to get the car driving well enough that I can enjoy it untill winter comes and the permaflex comes off and a long needed unibody-up restoration starts the topless conversion process. I put in many long hours (much to the dismay of my wife, who has almost forgotten what I look like) but have fixed the clutch leak and found the brake leak, and once I fix that and a broken shifter cable the car will move short distances under it's own power.
Meanwhile, I thought I'd mention a few things that need attention in case someone recognizes them and saves me a few hours of diagnostic time.
  • The engine(2.5L L4) idles high and runs poorly, and will randomly flood out at idle. I usually have to use clear-flood mode (pedal held to the floor) to restart it. Codes 15(CTS) and 35(IAC) are set, but I think the problem lies only in the coolant temp sensor, and the high idle is caused by the ECM running the engine way too rich based on incorrect (lower then it really is)temp data. I'm thinking this because the engine runs better cold. The cooling fan does not come on, and I think this is related...
  • Taillights, brake lights, and rear turn signals\hazards do not work. I think this is caused by a a bad ground since the high mount stop works as well as all the front lights.
  • Passenger headlight door motor keeps spinning sometimes, but will stop if thumped with the flat side of a fist. I'm wondering if this is repairable without replacing the entire motor assembly...
Wanted to buy:
86-88 Fiero GT, 5 speed, fixer-upper. Blown motor, no motor? No problem! Rusty unibodies need not apply.
74-79 Ramcharger or 100, slant or no motor - not interested in v8 - Overdrive 4 is a big plus, NO hopeless rust buckets!!!
3Rd gen F body floor pans/camaro door skin (L)
Why is it I see so many "Proud to be an American" bumper stickers on the backs of cars made in Japan or Korea??????
Ragtop_Renegade is offline   Reply With Quote
Old 04-26-2004, 08:49 AM   #2
RedFiero
Re: The 2M4 comes home!!
Good luck on the "Project" and be sure to include some before and after photos. My car(Tranny lock up problem) has found it's way back to the Trans place and is being looked at as we write. All problems point to workmanship/deleting of parts. I really wonder if he put the converter in as he said???? L8TR G8TR Nufsed
RedFiero is offline   Reply With Quote
