Register FAQ Social Groups
Old 01-31-2004, 02:17 AM
txcougar txcougar is offline
Leaking gasoling out manifold?
I hope you guys can help us out. My brother in law has an 83 Buick Lesabre with a 307. He claims iIt appears that gasoline is somehow leaking out the exhaust manifold and it has been terrible on gas mileage since he bought it a couple of weeks ago. He's also smelled gas coming from the engine compartment at times. It seems to be running okay other than this leaking gas and it only seems to leak when he first starts the engine? Hope someone can help.
Old 01-31-2004, 10:47 AM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Its likely the carburetor is bad, either the float has sunk or the needle and seat is bad. Either way the float bowl is being over filled and gas is flooding into the engine.
Old 01-31-2004, 05:33 PM
quaddriver quaddriver is offline
Send a message via AIM to quaddriver Send a message via MSN to quaddriver Send a message via Yahoo to quaddriver
Re: Leaking gasoling out manifold?
The E4MEs are pretty easy to rebuild, the kit is about $30 and will take a person with average ability about 2-3 hrs, plus cleaning time. throttle plate seals always go bad (usually need bushed) and the tiny bowl leaks into the bleed passage - does it idle like crap?
also, dont discount a bad cylinder not lighting the mix....Y-codes aint the best of motors....do a bit more research then report back
Old 02-15-2004, 10:26 PM
You guys were right bought a a kit for the carburetor and it took care of the problem. Thanks for the help!
liquid fuel leaking from exhaust manifold SoullessNihilist Blazer 9 11-15-2013 01:47 PM
exhaust leak fixed. intake manifold leaking! ghostrx7 RX-7 2 04-22-2005 12:10 PM
Oil leak under new manifold Webslinger60 General Discussion 1 04-21-2004 03:10 PM
Oil leak under new manifold Webslinger60 General Discussion 0 04-21-2004 01:40 PM
Leak in intake manifold. JB Weld?? integra111 Prelude 7 04-08-2004 06:36 PM
