Old 10-20-2003, 02:09 PM
jondaphenom114 jondaphenom114 is offline
Thumbs down 92 Lumina won't stay started!
My 1992 lumina alwayz stalls after 2 minutes of driving or less. Then it will not restart again until several hours later. (There is no spark.) I've replaced the ECM, ICM and crank position sensor already. Still no good. Not sure where to go from here. Any suggestions???
Old 10-21-2003, 10:28 AM
RABarrett RABarrett is offline
My suggestion is the ignition module, located on the underside of the egnine. Replace the crank position sensor at the same time. Though I cannot determine a cause without troubleshooting, this is likely the cause of your problem. Ray
Old 10-21-2003, 10:57 AM
The Burning Rom The Burning Rom is offline
Send a message via AIM to The Burning Rom Send a message via MSN to The Burning Rom Send a message via Yahoo to The Burning Rom
Re: 92 Lumina won't stay started!
He already replaced both of those...as he stated in his first post.
Have you checked your plugs and coils? Check the fuel pressure to make sure that is good. That's all I can think of right now.
www.wicgp.com <- Wisconsin Grand Prix Club
1999 Black Grand Prix GT Coupe
1990 Red ASC/Mclaren Grand Prix Turbo Coupe
1990 Metallic Blue & Silver Grand Prix LE Coupe
1979 Blue Dodge Ramcharger
Old 10-21-2003, 10:20 PM
takro takro is offline
92 lumina won't say started
The exact same thing happened to my 92 Lumina last week.Can anyone tell me where the ignition module is located & what it looks like?The parts store said they will test it if I bring it in.Thanks!
Old 10-22-2003, 09:55 AM
Re: 92 lumina won't say started
The ignition module is towards the bottom of the front side of the engine...underneath the front exhaust manifold. It has all the coil packs mounted to it.
It's a pain to get out, and it's a good idea to remember where all the plug wires go.
Old 12-15-2003, 09:34 PM
joel2180 joel2180 is offline
What I found
I had this same issue and found that there was some bare wires on the position sensor harness. The wires had oil on them and shorting out.
92 Lumina Won't Start ICM Voltage Brndo Lumina 9 05-03-2010 12:37 AM
95' Lumina won't stay running Jeremy Granite Lumina 5 07-29-2009 05:32 PM
93 Lumina won't stay running Caleb5505 Lumina 1 04-07-2006 06:38 AM
Lumina won't stay running joeg24 Lumina 6 01-26-2006 09:18 PM
'90 lumina won't stay running jdhammer Lumina 2 09-17-2005 09:22 PM
