Go Back   Automotive Forums Car Chat > GMC > General Discussion
Old 07-27-2003, 04:14 PM
lockdog lockdog is offline
Send a message via AIM to lockdog Send a message via Yahoo to lockdog
Question programing gm remotes
need to know how to program gm remote, are they all pretty much the same like the ford. if not please tell me if you know how?
Old 12-10-2003, 10:30 AM
JeffL. JeffL. is offline
Re: programing gm remotes
I found this from another post on this website. Might try it on yours???
Important! Once the BCM enters program mode, all transmitters must be programmed at the same time. Any transmitters not learned at this time will be erased.
1) Remove the key from the ignition cylinder
2) Remove the BCM PRGRM fuse from the fuse panel
3) Close all the doors
4) Close the liftgate
5) Turn the ign lock cylinder to the ACC. position
6) Turn the ignition lock cylinder to OFF, and then back to ACC within 1 second
7) Open and close any door
Achim will be heard when the system enters the BCM programming mode
IMPORTANT!
After 7 seconds a chime may be heard confirming successful synchronization. It is necessar to wait approximately 14 seconds for a second chime that will confirm successful programming.
8) Press and hold the transmitter LOCK and UNLOCK buttons simultaneously for 14 seconds
9) Repeat the previous step on each additional transmitter to be programmed.
10) Remove the ignition key from the ignition cylinder
11) Install the BCM PRGRM fuse back into the fuse panel.
'09 Corolla KeyFOB, keyless entry programming Question btrolla Corolla/Matrix/Voltz 1 09-03-2010 01:00 PM
Programming Transponder Key North_star Eclipse 2000+ 0 04-06-2010 07:20 PM
Dealer says new computer needed to program keyless remote, I think they are wrong.. hoover101 Sequoia 2 03-17-2010 12:17 AM
96 Camry CSI Program Keyless Remote JeanC Camry/Camry Hybrid/Vista 1 07-15-2009 01:28 PM
94 s10 remote keyless entry programing instructions needed stillblazin Problem Diagnosis 0 07-01-2009 10:39 PM
