Go Back   Automotive Forums .com Car Chat > Ford > Taurus | Taurus Wagon
Old 06-02-2002, 02:42 PM   #1
vampyr95Z
Question 97 taurus...abs light on
My fiances' abs light is on in her Taurus.I've checked the fluid level it's fine and the brakes don't feel any different.Any ideas anyone?????
vampyr95Z is offline   Reply With Quote
Old 12-15-2003, 05:57 AM   #2
pctoyou
Re: 97 taurus...abs light on
If the abs light is on, it meas that the vehicle ABS module has disabled the abs brakign features and you are runnign with non-abs brakes at this time. That is why it feels as if it has not changed at all. In this state, the brakes will work as if they are Non-abs.. IE: brakes will lock on a hard push of the pedal! Most likely cause of this is an ABS Toner ring that is a toothed gear ring on your front wheel drive axles cv joint. Other possible causes are bad abs wheel sensors and faulty wiring. Fords are known for the Toner ring Breaking for no apparent reason. do a inspect of the abs toner rings to be sure they are not cracked aor moving on the cv end towards the tire.
pctoyou is offline   Reply With Quote
95 Taurus abs light on khurdp Taurus | Taurus Wagon 0 02-21-2005 09:10 AM
1997 Taurus ABS Light ON cincin333 Taurus | Taurus Wagon 0 07-15-2004 08:32 AM
Removing a Taurus abs light bulb taurusblues Taurus | Taurus Wagon 4 07-14-2004 01:55 PM
1998 Ford Taurus ABS light.. Fenriz Taurus | Taurus Wagon 1 03-20-2004 04:47 PM
96 Taurus ABS light On tferrell Taurus | Taurus Wagon 1 05-14-2003 07:52 PM
