Headlight wires
Does anyone know which wires that come from the headlight are which? I believe the black wire is the common ground, however there is a wire with a green strip and a wire with a white stripe.
I own a 2000 XE 4x4. |
XTerra Guy
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2001
On my Canadian model the red/yellow wire is my high-beam. The low is red/silver.
I would always use a wire tester to make sure anyway. |
Too bad mine isn't Canadian
Thanks Schlud. Mine isn't Canadian. However, I forget about using the tester (smacks forehead). Thanks again.:smoker2:
XTerra Guy
ElectroKen's answer.
The black wires are indeed grounds. For the left headlight:
low beam = red high beam = red/green stripe right headlight: low beam = red/black stripe high beam = red/white stripe I'll let you figure out if he means left when facing the front of the truck or when sitting in the drivers seat. |
Thanks Buddy :)
That much I can do However, thanks again. Electroken also posted this for me on XOC. Thanks for the effort. :smoker2: |
DeFib -
What are you wiring up??? I just wired my offroad light to my highbeams. I have a 3-way switch so I can turn them off all the time, on or on w/ highbeams. It's nice to be able to cut off all your offroad lighting with one switch when you get out of the truck to watch someone conquer an obstical.
G o l i a t h ~~~ [email protected] ********************************* 33x10.5 BFG KMs on AR-767|ARB Bumper|SR Skid Plates|EOE Sliderz|2" Body Lift|Custom Rear Tire Carrier & Bumper| MAXC ********************************* |
#7 | |
DRL's
Without getting into the debate of the usefulness of DRL's that is what I am wiring up. However, I was unable to make it work correctly so I will be swinging by the local stereo install shop to see what they will quote to have it done there. :smoker2:
#8 | |
XTerra Guy
The Canadian DRL's are the highbeam bulb running under low power.
#9 | |
Wiring diagram
The wiring diagram for this module says that I hook up 2nd wire to the low beam and 1 wire to the high beam.
#10 | |
Well, after taking it to a stereo install shop that I trust implicitly. I found out that there is to much wattage for the module I bought. Don't ask me to go into details because I don't understand it all. What I do know is that it will not work. I think turning on the headlights manually will be a lot cheaper even though I will go through a few more headlamp bulbs it will still be as effective.:smoker2:
#11 | |
DeFib
Just out of curiosity, why do you want to run DRLs. Personally I don't like them.
#12 | |
DRL
Because I want to and I feel that is an easy way to make the truck more visible.
#13 | |
I guess the reason I don't like them is because the town I came from in FL was over half retired people. They seemed to have the tendancy to drive around at night with just the DRLs
. I guess they didn't realized that their headlights were not on, nor their tail lights.
#14 | ||
XTerra Guy
Re: DRL
