Register FAQ Social Groups
Old 09-06-2003, 01:42 AM
Santas90Si Santas90Si is offline
Registered User
Send a message via ICQ to Santas90Si Send a message via AIM to Santas90Si Send a message via Yahoo to Santas90Si
Exclamation Need advice
Okay I am looking into buying a motor and trans. Here is what is included. JE pistons 10.5:1comp.,Hastings rings,DC Sports header,STR blck.guard,ZEX sprgs.59300cam,Eagle rods h-beam,Matrix 9.3mm wires,JDM ECU SIR,all new Honda gaskets,Tenzo R muffler,Honda bearings,honda knock sensor,valve guides,timing belt,'95 Vtec head on D16 block(mini me),head surfaced, all machine work $500,new H2O pump,powdercoated valve cover,chrome oilcap valve cover airbreather. Trans.:ZC LSD trans.,new intergra axels,center force dual friction clutch,redline trans fluid,new Honda flywheel bearing and throwout bearing
But the catch is that the motor only has 3 good connecting rods. So I have to buy a new one. (guy supposedly over revved it.) I have an A6 block to transfer it all to considering there is going to be cylinder wall damage in the block.
Does it seem worth $800?
Old 09-06-2003, 01:45 AM
dirty91crx's Avatar
dirty91crx dirty91crx is offline
Send a message via AIM to dirty91crx
if its a true zc lsd tranny its worth about $500....i say go for it....but hopefully the head didnt get damaged by the loose piston.
so whats wrong with a d15b2 again?
Old 09-07-2003, 03:35 AM
Registered User
Re: Need advice
Originally Posted by dirty91crx
if its a true zc lsd tranny its worth about $500....i say go for it.....
How can you tell if it is?
Old 09-07-2003, 05:13 AM
dirty91crx's Avatar
its hard to tell from the outside....i can tell you this. one way to find out if it has an lsd....you wont see a differential pin if looking through the axle entrance.
Fender Bender - Need Advice on Repairs Panken202 Grand Cherokee | Grand Cherokee SRT8 3 10-24-2010 10:50 PM
82 rabbit may need engine, I need advice gengelman Rabbit 3 05-10-2005 07:52 AM
for sale 95 jetta runs needs work good project or parts car/ need advice for new car scooterman Jetta/Vento/Bora 0 01-03-2005 01:46 PM
a4, need advice, 97 a4, any need to start rust control (krown)?? ssdeluxe '94 - '01 2 02-19-2004 05:29 PM
i need a bmw and need advice needabmw 3 Series 1 03-14-2002 11:46 AM
