Go Back   Automotive Forums .com Car Chat > Mercury > Cougar
Old 12-17-2004, 08:46 PM   #1
badcat99
99 Cougar V6 How do you replace the Control Arms?
What is the proper method of replacing the Lower control arms on a 99 Cougar with a V6?
1. I cannot get the Ball joint separated from the Strut Bracket?
2. The front mounting bolt cannot be removed because the Transmission is almost sitting on the head of the bolt?
Do I have to lift the Engine/Trans. Not much room gained by this.
or do I have to disconnect the motor mounts and drop the Subframe?
How dificult is lowering the subframe?
I really do not want to remove the axles from this thing. I still have the problem of getting the lower ball joint out of the strut bracket?
Kris
badcat99 is offline   Reply With Quote
Old 11-20-2005, 10:15 PM   #2
mikecox1
Re: 99 Cougar V6 How do you replace the Control Arms?
Kris
why are you replaceing the control arms?
mikecox1 is offline   Reply With Quote
Old 11-20-2005, 11:54 PM   #3
badcat99
Re: Re: 99 Cougar V6 How do you replace the Control Arms?
The Bushings are worn out on the drivers side causing excessive tire wear only with that tire. I have also come to find out that I need
to install a camber kit to get the alignment within specs.
The car has over 100k on it. So it needs new motor and transmission
mounts. So what started out as a quick and simple Control arm change has gotten much bigger. Oh well..
I believe that in order to get the Ball joint to release from the strut
I just need to find a long pry bar and just force the control arm down
even though the bushings are still very springy.
Old 11-21-2005, 06:58 AM   #4
beyondloadedSE
AF Ford Contour-Advisor
beyondloadedSE's Avatar
Re: Re: Re: 99 Cougar V6 How do you replace the Control Arms?
sounds like its time for a 3.0L.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
beyondloadedSE is offline   Reply With Quote
