Register FAQ Social Groups
Old 09-05-2003, 12:28 AM
HPIracer HPIracer is offline
Send a message via AIM to HPIracer
How should i go about painting the chassis?
How should i paint the chassis on my 350Z? Its all one peice so can i just spray it all body color and then paint over that for the suspension and exhaust?
Old 09-05-2003, 08:49 AM
EMAXX's Avatar
EMAXX EMAXX is offline
Send a message via AIM to EMAXX Send a message via MSN to EMAXX
I think it would be better to mask off the areas, then paint. Then paint the supension and stuff.
Old 09-05-2003, 09:32 AM
Hmm thats a lot of detailed masking for my first model. Maybe ill just make it all black
Old 09-05-2003, 11:05 AM
fairladyz_gt-r's Avatar
fairladyz_gt-r fairladyz_gt-r is offline
Send a message via AIM to fairladyz_gt-r Send a message via Yahoo to fairladyz_gt-r
what i do is first i spary it, then i paint it. but u have to think before u act because if u mess up it mean sparying all over again
Old 09-05-2003, 12:02 PM
slk320 slk320 is offline
AF Premium User
Send a message via AIM to slk320
I have just finished off doing a 350Z chasis, so I can tell you how I did mine.
I sprayed entire chasis in dark gunmetal (in my opnion a better modern chasis color than flat black) and picked out initial nuts and bolts in silver using bottle paint (steel or alumin) than I sprayed the resonator box (whioch is a separate piece) with gloss aluminum. After all is dry attach the resonator to the main chasis plate and lay down a spray coat of dullcoat to kill the shine. I picked out the exhaust in aluminum and the headers in "steel" and I than picked out the drive shaft in titanium (but you can also lay down a carbon fiber decal that conforms to the drive shaft to represent cf driveshaft (if you are building a tuner)
Some interesting more-than-stock options would be to add the brake lines (they are not molded into the chasis of the kit) and to detail paint the nice brakes that come with the model) BTW the brake claipers can benefit from a small brembo decal on the front rotors if you are biuilding stock set up. These decals can be found on a number of DTM/GT or WRC decal sheets.
I will post a picture of my chasis for 350Z if you like for refference.
Old 09-05-2003, 04:03 PM
Thanks for the help. Ya pics would be nice
Old 09-05-2003, 05:17 PM
NortherntoucH's Avatar
NortherntoucH NortherntoucH is offline
Someone on another forum suggested that I use... "paint-on" mask for the paints... I tried it and it works really well. I think you can buy it at Michaels.
:.:Coming straight out of Canada:.:
:.:AkA Dj Distyll:.:
Old 09-05-2003, 08:40 PM
AF Premium User
here are the promised pics:
Chasis of 350Z Tamiya:
exhaust (still working)
