ignition problems on 94 S10
i was replacing a fuel pump relay on my S10 today i double checked the part #'s and it was compatible, i put everything back together. i went to start the truck and i get nothing from the ignition no crank no click. i have checked the fuses checked the battery cables cleaned them up with a wire brush still nothing from the ignition is there something i missed ? i have not tried to jump the starter yet as i have no idea where it is on this truck lol. embarrassed to admit that. any help is greatly apperciated
Registered Offender
![]() Join Date: Mar 2006
Re: ignition problems on 94 S10
Is this a 134" inline or the 262 V-6?
262 V6 Vin Z
just in case you wondered, no i never put the push button start on. all wiring is oem as far as i know.
Get a voltmeter and test your battery first.
Post back, that's what makes Forums Work. |
ok i checked the battery 12.65V, cleaned the cables. checked voltage at the dash for the ignition its getting 11.45V i checked all the grounds i could see. all my dash lights are working it seems i am getting power everywhere but the key when i turn it to start the truck.
#7 | |
on the picture the relay i replaced is the last one on the right. looking at pictures online. should i have more plugged in?
#8 | ||
Automatic? If so try starting in neutral.
#9 | |
the lights on the dash and radio shut off, i do not notice any dimming of the dome or mirror lights. when i put the truck in Neutral the key won't turn at all. key won't turn unless in park. no crank at all, i turn the key to start the truck and nothing happens. before this happened i was having issues with the truck dying and stalling out so when i had issues starting the truck one day i got a CODE 54 i looked up the problems that it could entail. so i went out and got a new fuel pump relay. before i did anything i disconnected the battery. switched the relay and hooked back up the battery. that's all
this is where i got info for the code https://repairpal.com/gm-obd-code-54 |
#10 | ||
How old is your battery? Have you tried to jump start it with another car?
#11 | |
yes i did try to jump it with another car still no crank or start .. the battery is less than 3 months old and the volts as of this post 12.50V
#12 |
#13 | |
guess i am goin to rent a steering wheel puller tomorrow to replace the ignition cylinder
#14 | |
As I recall- a '94 has the ignition switch on the steering column left side- driven by a push rod- no need to pull steering wheel...
Do what I would do- turn ignition on (pink wires will be energized now) then jumper (or cross up) your red wire to yellow wire on ignition switch plug---(big heavy wires) see if starter engages- if so- the bad ignition switch, if not then problem is elsewhere- as in tranny park/neutral switch. report back..
Automotive A/C Engineer with: '99 IH 4700 Toy Hauler (2) '95 GEO Prizms both maroon '99 GMC Yukon '95 Chev 3500, 454 Dually Crew Cab- 145k miles- Wife's Camel trailer puller. '94 Astro- 370k miles '94 Firebird Formula- 5.7L 180k miles- gone- '92 Chevy Lumina Van 3.8L 264k '86 GMC S-15 - 2.8L 154k '87 Buick Park Ave . 187k '86 Buick Park Ave 3.8L 199k miles- gone '77 Chevy Vega- 2.5L 175k miles gone but not forgotten '68 Camaro 396 4 spd RS/SS -72k miles- |
#15 | |
i was not able to get out to work on the truck today. the wires i am looking for is it on the same plug in for the wipers and buzzer or another plug that i need to find?
