Old 03-04-2006, 07:22 PM   #1
snooprawb
2003 Cavalier High Beams Not Working
My High beams for a 2003 cavalier are not working. I checked the bulbs and they are good, The Low Beams Work and my drls work. I switch from low to high and the blue indicator on the cluster panel comes on. Does anyone have any ideas on what the problem could be ???????????? plz help
snooprawb is offline   Reply With Quote
Old 12-19-2007, 11:17 PM   #2
bblomquist
Re: 2003 Cavalier High Beams Not Working
2002 cavalier same problem. Let me know what you find.
bblomquist is offline   Reply With Quote
Old 01-02-2008, 04:57 PM   #3
TonyP
My high beams just stopped working this morning. There are separate fuses for left and right not high and low, so it's not a fuse. Anyone with suggestions?
TonyP is offline   Reply With Quote
Old 01-02-2008, 05:17 PM   #4
bblomquist
My girlfriends 2002 cavalier had a corroded high beam wire located near the connector under the battery. To get at it I had to remove the battery and the air filter box. The pink wire (high beams) was corroded so I just stripped the wire and soldered a new wire in where it was corroded. You can ohm out the wires easily by disconnecting the connector under the battery and ohm out the wires from that connector to the headlight connector.
The Following User Says Thank You to bblomquist For This Useful Post:
kendq (12-23-2016)
Old 01-13-2008, 12:46 PM   #5
TonyP
I can see the connector but can't get to it. BTW the pink wire was already replaced by the dealer when I had a problem a while back.
Old 05-23-2012, 03:34 PM   #6
2000redsunfire
just a quick thank you to an old topic, followed pink back thru the harness below the battery (took out air box and battery) cut out of harness and ran a new wire to both headlights, and tada high beams again!!
2000redsunfire is offline   Reply With Quote
Old 12-23-2016, 03:09 PM   #7
kendq
Thanks to bblomquist my issue was the connector under the battery was corroded (2003 Cavalier)
Thanks again
kendq is offline   Reply With Quote
