Go Back   Automotive Forums .com Car Chat > GMC > Commercial Trucks
Old 08-12-2015, 12:39 AM   #1
bstrom1953
95 TopKick battery drain problem
This truck just had a new alternator installed and replaced the 8 year old batteries. The alternator charges properly.
Because we previously had times when the charged batteries would go dead overnight, I checked the current to ground with the key off. The ammeter immediately read 28 ma. About 20 seconds later it dropped to 18 ma. and then finally settled at around 8 ma. Is this normal? Shouldn't the current drain be zero when the key is off? Is the computer on all the time and draws that amount?
I pulled fuses at the fuse block mounted on the firewall and found two 40 amp circuits where the current was going...around 4 ma each. FYI it has a Cat diesel engine. I'm just wondering how long two big 12 volt batteries will hold a charge with 8 mils of current going to ground.
Thanks for any ideas.
bstrom1953 is offline   Reply With Quote
Old 08-12-2015, 11:16 AM   #2
DeltaP
Re: 95 TopKick battery drain problem
8ma is about what the ecm will draw. That shouldn't make a dent on a pair of fully charged group 31 batts in parallel. What other accy's on the truck? Lift gate, refrigeration unit? Lift gate only being used while truck is running?
DeltaP is offline   Reply With Quote
Old 08-12-2015, 11:34 AM   #3
brcidd
brcidd's Avatar
Rule of thumb is anything less than 50 ma draw is fine.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
brcidd is offline   Reply With Quote
Old 08-12-2015, 12:11 PM   #4
DeltaP
That's some driveway you got there.
