Go Back   Automotive Forums .com Car Chat > Nissan > Altima
Old 10-14-2011, 02:15 PM   #1
iimar10ii
Rough/low Idle on 2003 Altima.
Hey guys, My 2003 Altima 2.5 SL has a really rough Idle. It's way below 1000 RPM's when I'm Idling (in park or at a red light) and if I turn the AC on it gets worse and the engine rumbles and makes a rough noise until I accelerate and push the RPM's higher than 1000 RPM's. Putting the Car in neutral also pushes the idle speed back to where it should be for some reason. There's a check engine light on and I've tried the reset procedure where you disconnect the battery and all that and it did not work. What can I do to solve this problem? Do I replace the throttle body or the Idle Air control motor or both?
iimar10ii is offline   Reply With Quote
Old 06-25-2016, 06:57 AM   #2
Eddiegari
Re: Rough/low Idle on 2003 Altima.
I have the same problem with my 05 altima 2.5 can anyone help please
Eddiegari is offline   Reply With Quote
95 tsi really low idle and stalls.. Please help please Brenthb25 Eclipse Problem Diagnosis 3 07-20-2010 11:41 PM
'96 Camry 4-cyl 2.2L Idle Control Sensor Maulana Camry/Camry Hybrid/Vista 4 03-18-2010 11:29 AM
low idle/shuddering adamthecaveman Tercel 1 03-03-2010 08:38 AM
99 Taurus 3.0 duratec rough/low idle mudhen33 Taurus | Taurus Wagon 2 11-24-2007 03:08 PM
2003 Altima, Ticking noise, idleing rough chucksball Altima 6 04-02-2006 07:26 PM
Tags
altima , idle
